Crossfire Rebuild
Old Jan 24, 2012 | 09:57 AM
Stickman82's Avatar
Stickman82
Default Crossfire Rebuild
Preparing to removing the throttle bodies from my '82 for new bushings (100K miles). Any recommendation as to who I should send them to for a quality rebuild back to OEM spec?
Thanks!
Old Jan 24, 2012 | 10:23 AM
Marlin's Avatar
Marlin
not sure myself but if keeping the crossfire and car also see about getting them bored as well. If you have them off go the full distance.
Old Jan 24, 2012 | 10:26 AM
Stickman82's Avatar
Stickman82
Thanks for the tip!
Old Jan 24, 2012 | 10:29 AM
LastC3AZ's Avatar
LastC3AZ
You mite try getting hold of the guys at DCS for your TB work ......
http://www.crossfireinjection.net/
Old Jan 24, 2012 | 10:31 AM
Stickman82's Avatar
Stickman82
They were my first choice but called them twice and e-mailed yesterday. No answer and no response.
Old Jan 24, 2012 | 11:13 AM
7T1vette's Avatar
7T1vette
If you haven't done so already, just search the web for "fuel injection throttle body rebuilders" and check out the sources that come up. One is "LTS" and is listed as "GM TBI Rebuilding". You can also get a rebuilding kit from some of the auto supply stores. I don't know if they carry a shaft rebushing kit (with reamer) or not.
The LTS write-up is interesting...especially about using a 1/4" spacer to attain "15% more airflow". But, I would think you should get larger injectors installed, if you really would get that 15% more airflow. Might be worth a call to them to investigate.
Old Jan 25, 2012 | 07:55 AM
LastC3AZ's Avatar
LastC3AZ
send a note to Tom directly .... he'll get back with ya ....
Tom@crossfireinjection.net
Old Jan 25, 2012 | 08:33 AM
Stickman82's Avatar
Stickman82
Thanks for the tip!
Old Jan 25, 2012 | 04:18 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
I just did mine myself last week!
I bought another set of TB's that I am going to have a friend machine and then use the reamer I bought. My drill press was not big enough for the reamer. I used .375 bushings, my shafts were .371 so I am back to square one as how they came from the factory, .004. By reaming undersize bushings I can get to .373 or .002. The car runs great again!
To Crossfire Rebuild
