AFR Head choice for small block
How much for just a sportsman shaft system.
Have you looked at the airwolf head. 23 degree, 265 runner, 64 to 72 chambers, 2.15 intake valve, 40/60 valve spacing www.j-performance.com or the all pro 23 heads in 245 to 290 runner 2.18 intake valve www.allproheads.com
I've seen some of the cheaper shaft systems for $900 for only $300 more you can get the T&D
But I need offset shaft rockers. Both on my present heads or future heads. My springs are a couple of years old and the guides are using oil. They are $ 600 dollar springs and doing the heads are another $300 So the way I see it I would have spend over $2000 to refurbish my heads & rockers or get the new AFR at a great price for about $4000
Those airwolf heads have room to grow. 2.15 valve size 265 runner. $2500.00 bare say $ 700.00 for springs, $300 valves, $1200.00 shaft system $4700.00. $700.00 more for more potential. 265 runner is not to big for a 434 like you have.
Scott
Pistons were about $800 a set of 10 or so. milling is only $280 When youget into 434 pistons they are for race motors. So they are made for big valve and clearance to .800 lift with altered valve angles. When you get into real chevy small block racing heads they have tiny flat chambers as small as 38 cc to get 15-17 C/R for alki motors. So 60 cc heads only gets me to 11 ish C/R
Big cubic inch small blocks become under valved
If you could run a flat-top piston, you could use a 64cc combustion chamber head. There is a large selection of heads with this combustion chamber size. You could keep SCR up and have a larger assortment of heads that wouldn't require as much modification to choose from.
I understand that with a 4" stroke, compression height of the piston would have to correspond to that measurement, and there isn't a lot of demand for pistons at that level, which means a small selection of available pistons, and you have to use whats available. Also, I don't know much about the heads available at that power level. But I enjoy learning about this sort of thing, and I appreciate you guys letting me take part in this discussion.
Scott
You want to keep piston weight at a minimum. So the piston top is a trade off. weight vs strength. So when you are making a race piston and the majority of your market is running 2.15 - 2.20 intake valves and .800 lift numbers you have to design deep valve clearance pockets. If you tried to machine a flat top piston to clear big diameter intake valves for .800 lift that you would go right through the top of the piston.
So when I say that my pistons are 15 or 16 cc it is not like a low compression stock dished piston. It has big valve clearance.
Because the valves are at an angle the piston cuts are very deep with bigger diameter valves.
You don't find 434, 441, or 447 ci pistons in a book. Only a few manufactures sell them and they call them custom pistons. That is why you get 10 in the box. So you have a spare when you blow a hole in one.
real racing heads are very small cc chambers with small valve angles. They figured out long ago that big chambers need a big cooling system and all that wasted energy just heating the water and poor flame travel. Look some time at a modern rice bike motor cycle chamers with 4 or 5 valvles. It is not even a chamber, it is nearly flat. Any dish is on the piston side.
As to your question 434 pistons are really made for heads with 38 - 58 cc chambers
My next motor BTW, a few years away yet when I am ready to open the piggy bank
Your going to sink $1200.00 in a shaft system for 23 degree heads.
Scott
