AFR Head choice for small block
Old Jan 25, 2012 | 12:37 AM
gkull's Avatar
gkull
Default AFR Head choice for small block
I have been offered a good deal on built up AFR Eliminator Racing Cylinder Heads in 245, 235, or even Competition ported 227 cc.
All of them with T&D 1.7 shaft rockers, upgraded springs, titanium retainers. I was told that the 245's were worth 25 extra HP from 4500 - 7500.
The problem I have is I don't want to drop crompression. So the 245 & 235 would require angle milling to go from 70cc to about 62cc. By the time that it is all done angle milling and figuring out intake milling...... It is another $600 bill or so.
Is any body out there happy with comp ported 227cc?
When you look at the head flow charts. Look at the .700 lift numbers because that it where the valves will be lifted to
http://www.airflowresearch.com/index.php?cPath=24
Old Jan 25, 2012 | 11:03 AM
Shark Racer's Avatar
Shark Racer
What are you running now?
IMO $600 for an extra 25HP is still hard to beat. Most people pay $3-5k for an extra 100hp from a stock motor.
Old Jan 25, 2012 | 11:59 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I would go with the 227 competition ported. Milling the bigger heads will reduce the flow numbers. How much I don't know but with the extra work and $$$ it takes to get them right for your application quite possibility they won't do much better than the 227's by the time they are milled. They were designed to flow with big chambers. Might want to look at your existing intake. Will the existing port sizes work with the 227's? If not add intake porting to the bill.
Old Jan 25, 2012 | 12:21 PM
bluedawg's Avatar
bluedawg
I personaly havnt went any bigger than 195's. But with displace ment your running, it might be best to change the pistons to achieve the desired compression ratio so that you can run the 245's. Just my .02$
Old Jan 25, 2012 | 03:20 PM
gkull's Avatar
gkull
I'm refreshing my 434. The problem is the pistons are 15 - 16 cc dished. They are more like for a blower motor using 75 cc heads. I have been using 60 cc to keep compression up.
I'm kind of screwed either way because pistons are $900
The good deal on the optioned heads is like $3500 for the 227cc and $4100 for the 235/245
Regular price is like $2029 for 227 heads $1170 shaft rockers $680 springs $185 titanium retainers What ever the sales tax would be. all ready to install delivered to my door
Old Jan 26, 2012 | 02:22 AM
bluedawg's Avatar
bluedawg
I would still vote pistons. Angle milling heads becomes a game of fitment, not saying it can't be done, but can be a pain in the ***, I'm not aware of angle milling damping flow.600 is cheaper than 900.
Old Jan 26, 2012 | 02:34 AM
cv67's Avatar
cv67
St. Jude Donor '05
Id flat mill as far as you can and call it done
Old Jan 26, 2012 | 03:39 AM
scottyp99's Avatar
scottyp99
Do you have any room to play with gasket thickness or deck height?
Scott
Old Jan 26, 2012 | 05:20 AM
gkull's Avatar
gkull
AFR suggested the angle milling because you take less metal off the head to make less chamber cc. You mill and then rebore the head bolt holes. You fit and then machine the intake manifold and often use bigger thicker intake gaskets
Steve, Dart heads that only flow 306 CFM. So the jump to 320 cfm with afr 227 comp ported might make the motor run. I need shaft rockers anyway. My rocker arms are at an angle now and head guides go bad in just a couple of years with my high lift
Scott
No I'm using a Cometic MLS heads gasket of .030 and a .005 deck height to get a .035 quench. I just ran a online compression calc program and my C/R is @ 11.42. for some reason I was thinking that I had 11.7.
My roller cam is so big that I can drive around with super unleaded. The DCR was not all that high for a performance motor.
4.155 bore 4.00 stroke -15 pistons 62 cc heads .030 gasket .005 deck
Old Jan 26, 2012 | 11:40 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I wouldn't mill anything and I would get AFR to port match the intake, what's the use in paying for 320cfm heads and the intake isn't perfectly matched to the head. I had my 227's flowed with and without the Vic Jr intake that was port matched at AFR and there was a 3% different with the intake bolted on. You could get 10-15% or more loss if it is not perfect and there goes $600 down the drain.
Once you get the shaft rockers you will never go back to anything else the stability of the shaft rockers is incredible.
Old Jan 26, 2012 | 11:49 AM
RobbSalzmann's Avatar
RobbSalzmann
St. Jude Donor '12
With a set up like that, why not run the afr heads unmilled and a supercharger?
Old Jan 26, 2012 | 12:01 PM
Shark Racer
@MotorHead - how much was it to have the intake port matched at AFR? I'm tempted to go down this route for a future build. I'd like all of my components to play nicely together.
Old Jan 26, 2012 | 12:42 PM
gkull's Avatar
gkull
AFR talked me into 245 cc or a minimum of the 235 cc heads angle milled and the intake side cut for standard big single plane. I'm just waiting for the quote.
Robb, I know for $4000 I could do a supercharger. Every time I hit the go pedal I wonder if I'm going to hear bad noises from the tranny back
Shark Racer, port matching on a quality intake is only a couple of hours labor
Old Jan 26, 2012 | 05:44 PM
RobbSalzmann
St. Jude Donor '12
That makes sense. $4k might get a huffer spinning on the intake. The rest of the story from the bell back is yet another small fortune.
Remember, you can easily make those noises go away by turing up the radio...
Old Jan 26, 2012 | 06:42 PM
cv67's Avatar
cv67
St. Jude Donor '05
Yes been there done that. Thought in case you want to avoid the stuff associated with angle milling. Sounds like youre willing to do it right
Same boat as you, 230cc Dart heads at 300ish on a good day...love to have a slightly smaller but better flowing head.
Youll love shaft rockers they are the cats azz. NO movement
Old Jan 26, 2012 | 06:57 PM
MotorHead's Avatar
MotorHead
It was an extra $200 but I bought all the parts from AFR I would not put a motor together without doing this again. You can look down the intake and see they line up perfectly. Shaft rockers are expensive but once you have them on a motor you will never go back
Old Jan 26, 2012 | 10:56 PM
Solid LT1's Avatar
Solid LT1
We angle milled my AFR's from 72cc to 64cc chambers. Angle milling and intake face correction ran around $240 for the pair at the Machine shop I used. Flow numbers didn't decline in my testing. As far as I can remember, it was an 0.080" cut on the major side to get the reduction.
To AFR Head choice for small block
Old Jan 27, 2012 | 12:10 AM
gkull's Avatar
gkull
My AFR race ready 210's were flat milled to 64cc They were nice heads for a 383. I do have this question if the 245 cc really are to big if I was just doing 3000 rpm driving down the street or should I say highway in OD. Because AFR said they were for racing big SBC between 4500 and .............. rpm
Always big problems when building a motor
Old Jan 27, 2012 | 01:29 AM
Shark Racer
When I look at the head #s, they flow better at low RPM and are smaller runner than the LS7 heads, I don't see why they'd be an issue.
LS7 heads have less flow @ low lift (<0.5) and are bigger (265cc), and I have no complaints. I'm sure your cam will be the deciding factor for low end torque. You're running a little over 427ci right?
Old Jan 27, 2012 | 09:34 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Curious on why you decided to go with dished pistons when you built your engine if you had to mill the heads to bump the compression back up?
