New style axles
This is awesome! So, how exactly do you know this?!?!
I can assure you most certainly that you are wrong, these are close personal friends of mine, the guys that I hang around with!!!! The only changes are installing DTE rear end girdles, and the C5 guys change the output shafts to C6 ZO6 units. Stock CV joints and half shafts.
This is really going nowhere fast, isn't it?!?
Do you understand how you just contradicted yourself? Jeezus h. buddy, you sound like a ricer. "Yo yo, my civic is totally stock except for dis turboz, yo"
You do know what "stock" means, right?
Multiple people in this thread have now tried to explain to you that with a u-joint axle pointed straight, there is no more loss than a live axle or CV joint. The miniscule difference, if it was even measureable, would be due to the inertial moment of the shaft (as Skunkworks mentioned earlier) and not the design of the joint.
We know the U-joints can as our half-shafts are under constant compression in the normal state.
The solution is to modify the rear suspension such that you have an actual upper strut rod and the half shaft no longer performs a double duty.
So, if they are so inferior to u-joints, then why are they pretty much universally used by every auto manufacturer in modern cars?
European rear wheel drive cars use central mounted diff with CV axles.Opel, BMW, Jaguar,Mercedes Benz....on and on and on.Axial movement is taken out by using a strut type suspension just like in the front drive junk.Or double wishbone as the case with the older jags.
Have been messing with cars my whole life and I have never seen anything like the C3 rear setup.Even the German engineers at my inspection station dropped there jaws when I explained to them why I didn't "need" an upper control arm.
Ya used to see a lot of 'em (Jag rears) all chromed up under the back end of hot rods like T-buckets, high-boys and so on.
Pete
Name one modern production vehicle that uses u-joints on the half shafts in an IRS rear wheel driven configuration, or even a 4 wheel drive vehicle with an IRS. I'll wait.
WTF are you talking about? How did I contradict myself? Who is the one that isn't paying attention here? The subject of this thread is CV joints, which I clearly stated are stock on the cars I mentioned that my friends own, along with the halfshafts. They did mods to other parts, but not the CV joints or halfshafts. The mods they did have nothing to do with the CV joints or half shafts.
Go on, scroll back to my previous post and re-read it again.
So, yes, I do know what stock means, in relation to CV joints and halfshafts.
Multiple people in this thread have now tried to explain to you that with a u-joint axle pointed straight, there is no more loss than a live axle or CV joint. The miniscule difference, if it was even measureable, would be due to the inertial moment of the shaft (as Skunkworks mentioned earlier) and not the design of the joint.As for being telekinetic, I never said I could move things with my mind, so WTF are you talking about?
No one knows everything, and I am always willing to learn, but other than trying to shove your opinions down my throat, what exactly are you trying to teach me? What exactly is your point anyways? That u-joints are superior to CV joints?
My only point, which I have clearly stated several times already, is once again simply this, and this time I will type it slowly so you can understand it easier:
For the entire auto industry to universally, across the board, accept the use of CV jointed halfshafts in modern production IRS 2 or 4 wheel drive cars, the advantages of using them must outweigh any advantages that u-jointed halfshafts have. This is true for the cheapest to the most expensive cars produced. Progress means moving forward, not back.
I still think you should contact all the world's auto manufacturers and tell them they are doing it all wrong using CV jointed halfshafts!
Yeah, nice of you to narrow it down like that. I can name you many vehicles that still roll out of the factory with u-joints, but you specifically want IRS vehicles? Ok buddy.
You might as well try to find a modern computer controlled mass production car with a carburetor. I've explained to you several times why CV joints are preferred in an IRS setup. But you simply can't comprehend this.
crystal clear yet?
buddy, they want you back at the Billy-Joe-Jim-Bob hillbillybutf*ckr 4-wheel drive Alabama mud bog U-JOINT forums ,where you belong
I would say that inertia generally increases as weight increases, but I would not say that weight necessarily increases with inertia.
Annnnnd this has been covered as well.
Rather ironic that he accused me of being the idiot redneck in that same post wouldn't you say?
Anyone who would like to abandon this epic fail and resume actual discussion on the possibilities of doing CV's without arguing over their merit, feel free to assemble here...
http://forums.corvetteforum.com/c3-t...post1579862153
Yep, when straight, or nearly so, there should be no loss of HP.
