9" Diff conversion
Old Jan 28, 2012 | 11:44 AM
dpw21562's Avatar
dpw21562
Default 9" Diff conversion
Has anyone converted the "80" diff to a 9" center section OR know a company that does one? It has to handel 575 HP.
Old Jan 28, 2012 | 12:54 PM
uxojerry's Avatar
uxojerry
Downs industries does a ford 9" for a corvette. You can also go with a Dana from a C4.
Old Jan 28, 2012 | 06:35 PM
Bee Jay's Avatar
Bee Jay
Will a c4 Dana 44 bolt up to an 80-82 C3 batwing?
Old Jan 28, 2012 | 06:42 PM
tracdogg2's Avatar
tracdogg2
nope
Old Jan 28, 2012 | 07:17 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Bee Jay, for whatever reason the C4 D44 doesn't share the same mating surface or bolt pattern with the C3 D44, so an adapter/mid-plate would have to be designed and fabbed up, which would add weight and length... However, if you can justify the effort and expense you could always fab up new mounts for mate the narrower C4 batwing to your chassis. FWIW, you might well be a good candidate for just doing the whole C4 rear suspension while you're at it.
Old Jan 29, 2012 | 05:21 AM
Jason Staley's Avatar
Jason Staley
Cruise-In III Veteran
This is probably more than your looking for, but Heidts makes a 9" based independent (similar to a Jag I think) rear suspension. It replaces everything from hub to hub.
http://www.heidts.com/heidts_superid...e_package.html
Old Feb 18, 2012 | 03:49 AM
Jason Staley
Here's another option I just ran across from Dutchman Motorsports.
http://www.dutchmanaxles.com/product...rd-independent
Old Feb 18, 2012 | 06:41 AM
TPIShark's Avatar
TPIShark
For high HP, I really don't like the small halfshafts on this that also act as the upper control arm. Go with the Tom's components offered by some of the retailers on here. 12-bolt based to "Keep your GM all GM".
Old Feb 24, 2012 | 11:59 AM
dpw21562's Avatar
dpw21562
Default Diff
Anyone outthere used this unit?
To 9" Diff conversion
