Rear Wheels "Bent out"
Old Jan 28, 2012 | 01:48 PM
Jon76's Avatar
Jon76
Default Rear Wheels "Bent out"
Hello all, me again with another noob question.
My '79 is all stock and was bought with practically everything from 1979 including the rear wheels being bent out.
I asked a friend about that and also the dealer who sold it to me and both said that they're like that so as to prevent the car from flipping while taking hard turns at fast speeds.
However, I'm no racer and I don't like to run so I won't be needing that.
My first question, is it true that they were built like this?
And my second, how can I straighten them up?
Old Jan 28, 2012 | 01:59 PM
Alan 71's Avatar
Alan 71
Hi J76,
It sounds like the rear strut rods need to be adjusted.
Looking from the rear... do the wheels/tires tip in or out at the top?
I believe with a proper rear alignment they should tip in at the top just a couple of degrees.
Regards,
Alan
Old Jan 28, 2012 | 03:00 PM
mrvette's Avatar
mrvette
Anything stock on that camber will hardly be noticeable the causes are one of two things, the lower strut bushings are #1 to check and certainly easy....look that the strut end loops are concentric with the bolts that pass through them....if not, the bushings are bad....
the next check is to jack up the rear, leave the wheels dangle, grab the wheels at 3-9 o'clock and alternately wiggle back and forth hard as you can...feel any clunking/looseness on the axle?? if not and you get nearly zero movement, the bearings are fine.....NOW grab at 12-6 o'clock, and do the same alternate in/out now if the driveshaft is loose on the diffy end you maybe feel lots of play on that if there is, the output yokes are bad, and you have to remove the diffy to change them....they wear on the diffy cross shaft, famous on later shark differentials, and I replaced mine on the '72 even, with hardened ones in the midst of a rebuild....
Old Jan 28, 2012 | 03:31 PM
Stoge's Avatar
Stoge
I wouldn't believe that.
My '79 was exactly as you describe. Strut rod bushings were shot, trailing arm bushings were shot, and diff side yokes had 1/4" of play. Not saying this is exactly what is wrong with your car, but they're the usual suspects.
Old Jan 28, 2012 | 09:11 PM
Jon76's Avatar
Jon76
When looking at the car from the back the wheels kind of tilt inward. (IE, the driver's side wheel kind of "tip toes" on it's lower left side.)
Old Jan 28, 2012 | 09:57 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
If you saying that the tops of the rear wheels tilt in and the bottom tilt out, it can be several things:
1. Bad strut bushings
2. Bad axel retainers/clips
3. Flattened rear spring
4. Struts out of proper alignment.
If it is happening to both wheels, I'd almost bet it is the rear spring.
John
Old Jan 28, 2012 | 11:06 PM
Jon76's Avatar
Jon76
Messed up the previous post. What I basically mean is that it's as if the middle of the axel was causing bending inward towards the floor. (Let's say that the axel was in fact just a straight bar that went through both wheels. Sorry if my mechanical handicap is confusing anyone.)
Also thanks to all those who have replied.
Old Jan 28, 2012 | 11:43 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
From the back do the wheels look like a V or an A?
Old Jan 29, 2012 | 12:01 AM
Rally68's Avatar
Rally68
The Gulstrand performance/racing specs for rear camber on a C3 are 1 deg negative (tilting in at the top) max; for touring it's 0 deg min to 1/2 deg max. This amount is barely noticeable; if your rears are showing a noticeable amount of negative camber, you need to find out what's wrong and correct it. Worn suspension bushings or loose camber cam bolts can cause your car to be very squirrelly. The suspension is designed to increase (negative) camber as it is compressed, so a weak spring could be the issue, but I'm guessing if she's knock-kneed enough for you to ask on here, you have other problems.
Old Jan 29, 2012 | 02:55 AM
Garys 68's Avatar
Garys 68
Answer 1: no
Answer 2: rebuild the rear suapension, including differential yokes
Old Jan 29, 2012 | 11:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Take the car to an alignment shop and have it checked. An alignment might be all you need.
Old Jan 29, 2012 | 11:31 AM
Mike Ward's Avatar
Mike Ward
Not sure about the 'bad spring' comments. Incorrect ride height is FAR more noticeable than the resulting minor change in wheel camber.
Old Jan 29, 2012 | 11:40 AM
kidneyboy's Avatar
kidneyboy
The rear wheels on my 78 looked like a "A" but after an alignement and a little tweaking all is good.
Old Jan 29, 2012 | 03:36 PM
Jon76's Avatar
Jon76
They're shaped more like a V.
Old Jan 29, 2012 | 04:45 PM
Paul L's Avatar
Paul L
Show us a photo.
Old Jan 29, 2012 | 06:38 PM
Jon76's Avatar
Jon76
It's kind of hard to see here. Someone's always parked behind it, making it difficult to take a good picture.
Old Jan 29, 2012 | 06:45 PM
Jclgodale3's Avatar
Jclgodale3
I think you meant an "A". Tops tilting inward and bottoms outward based on the picture. In other words, the distance measured between tires at the top would be less than the distance measured between the tires at the road (bottom)
To Rear Wheels "Bent out"
Old Jan 29, 2012 | 06:56 PM
Paul L's Avatar
Paul L
Hard to tell but it looks like regular (-) camber.
Old Jan 29, 2012 | 07:42 PM
Jon76's Avatar
Jon76
This! That is exactly what's going on!
Old Jan 29, 2012 | 09:14 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
1 Strut bushings shot
2 Side yokes worn
3 bad spring
4 needs alignment
5 a combination of 2 or more above
