Borgeson P/S conversion- just finished
Old Jan 28, 2012 | 02:33 PM
lonebull's Avatar
lonebull
Default Borgeson P/S conversion- just finished
I just finished replacing the power steering in my 78 with the Borg. kit from Summit & it is impressive. This was part of a new engine replacement so I went thru the new cam break-in procedure & once I shut it off I refilled the p/s resovoir & jacked the front up to purge the steering system. At this point I had not moved the steering wheel at all. The system seemed to have already purged itself. The steering never squealed or made a noise of any kind. It was simply ready to get up & go! The steering is more responsive & much improved the look under the car. I learned of this swap on this forum & wanted to say thank you to everyone who participated in the conversation. I also wanted to report that this is really a good idea & that the swap went smoothly. The Borgeson kit turned out to be a quality product just as most members reported. Thanks again!
Old Jan 28, 2012 | 06:49 PM
redwingvette's Avatar
redwingvette
Glad it work out for you as well as it did for me.
Install
Old Jan 28, 2012 | 07:57 PM
Paul L's Avatar
Paul L
How did you shorten the steering column?
Old Jan 28, 2012 | 09:03 PM
gbarmore's Avatar
gbarmore
Hey Redwing, looks like you're overdue for some new control arm bushings!!
Old Jan 28, 2012 | 09:45 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've had it on my car for a couple of years now. Drives great and not a leak anywhere!
JIM
Old Jan 28, 2012 | 10:11 PM
lonebull's Avatar
lonebull
Paul allof the details can be found by doing a quick search of this topic but for me it was a bit easier because the motor was out. The steering col. will "collapse" if you beat the hell out of it! In my case I made a capped tube just a bit larger than the col. It must be forcibly struck tp shear the plastic tabs that allow the col. to collapse. Once you shear the tabs you tap the col. slowly up until you achieve the length you need ( determined by slipping the new rag joint on the col. & then slipping the new box into the rag joint & into position on the frame)- again- all explained by members in much greater detail- check it out. This is a really a beneficial modification. lonebull
Old Jan 28, 2012 | 10:12 PM
682XLR8's Avatar
682XLR8
JIM
Same here
Old Jan 29, 2012 | 08:06 AM
redwingvette
I pulled the column out of the car and placed it on a block of aluminum. Then I smacked the shaft with a hammer until the shaft started to move. I placed a small block of aluminum on the shaft so as not to damage the splines when I hit it.
Old Jan 29, 2012 | 08:10 AM
redwingvette
Yea, I should have used poly bushings when I did them about 15 years ago. Maybe this spring I can replace them again.
Old Jan 29, 2012 | 01:31 PM
pancake's Avatar
pancake
I also just completed the borgeson install in my 78. The difference is amazing! I was actually able to collapse my steering column with a small piece of 2x4 and a hammer. I actually had to use a pair of vice grips on the shaft when i installed the rag joint because of how easily the shaft collapsed.
Old Jan 29, 2012 | 04:07 PM
Shark Racer's Avatar
Shark Racer
Did you collapse the column in the car or out?
Old Jan 29, 2012 | 04:13 PM
pancake's Avatar
pancake
In.. It moved with very light tapping on a piece of 2x4. I was using a 28oz ball peen hammer... The vice grips prevented me from pushing the splined section back up into the column.
I was also in the middle of installing long tube headers so I had removed the stock manifold and had plenty of room to work. It'd be a bit tighter with headers in the way.
To Borgeson P/S conversion- just finished
