Help with Vortec/E-Street Head and Cam built
Enter Cylinder Bore Size 4.030
Enter Piston Stroke Length 3.48
Enter Head Gasket Bore Diameter 4.10
Enter Compressed Head Gasket Thickness 0.015
Enter Combustion Chamber Volume In CCs 70
Enter Piston Dome Volume In CCs Negative For Dished Pistons (Use '-') 6 cc
Enter Piston Deck Clearance Negative If ABOVE Deck (Use '-') : 0.040
When I use those numbers, the calculator says 10.6:1 ratio. What number am I doing wrong?
If I enter it as a domed piston, I get your 10.6, if I enter it as dished, it's 9.3
Elm
I've run into things over the years when assembling motors and it always boils down to the details- If you don't check everything, then you've really not checked anything because it's what you DIDN'T check that will bite you in the end.
I can understand and appreciate being on a budget (4 kids in college here!) but the piece of mind knowing your bottom end is in good shape for the price of an oil pan gasket is priceless.
I just put my 409 SBC together less than 1000 miles ago and I am now swapping heads (ports were WAY too big for my application) but I still dropped the pan to double check the condition of my bearings and my side clearances- Maybe I'm a bit **** but I can now rest easier knowing they are perfect!
Elm
This is one of those things where you may want to post in your regional forum to get another pair of eyes on the engine. It's just a tough call for anyone to make by remote control. No one here can accurately assess the risk level and help you make the right decision.
If I this was 5 year ago and I was not married, the block would be down to the shop already. But its hard to explain my reason for someone who see's this as a money pit and not a hobby. But nothing another trip to Iraq of Afghanistan wont fix.
So on the piston volume, any dish or valve relief on the piston is considered a negative number?
I don't know why my wife tolerates my hobbies...but she does.My stepson comes home from Afganistan in April...and he's buying an S2000. Bleh
Yep, reliefs or dish is a negative number.
Now my neighbor also noticed that the babbitt on the cam bearings are wearing on the low side.
So I am wondering if it is worth rebuilding at this point.. I dont need a precision motor but I dont want to dump 1500 into a top end and have it grenade in a little while... But to be honest, I dont have cash to do a full tear down and rebuild.
Thoughts??
Are some of the pistons .040" in the hole, and others .060" in the hole? Or are they all over the place between .040" and .060"? I'm asking because if some are .040", and some are .060", you may have pistons with 2 different compression heights. I know it sounds crazy, but stranger things have happened. Also, have you got the deck nice and clean? Any crap left from the old head gasket will affect measurements. Not trying to question your intelligence, just being thorough.
Scott
As for the measurements, they seem to be all around. Passenger side seem to higher than the passenger side though. 0.040 to 0.050 and the drivers side seems to be 0.050 to 0.060. Plus the measurement around each piston yeilded slight variations as well.
As far as cleaning the block off, I have done all that a razor is going to do. It looks clean, but as I am finding out, an imperection the size of a human hair can change a meansurement significantly. When I did take a measurement, I made sure that the area was as clean as possible..
Can anyone guess what a shop would charge to deck the block and put new cam bearings in it? Keep in mind that my pistons are in right now so there would need to be some tear down and reinstall time added as well. And on top of that, might as well do new pistons as well? My fear is doing all this work to a 40 year old engine might not be worth it.
