Dave Fielder is certainly "The man" on this subject. Do you still have all stock components? I used one of the replacement modules, and still had some issues. Had to change the amplifier box extension wiring to solve problem. Has something to do with the spring tension on the female terminals losing their grip on the male terminals they connect to. Dave said it was imperative that the amplifier box extension wiring be replaced when installing a new TI box module. This may apply to existing stock modules also.
Ralph.
your saying the "R" terminal on the starter solenoid only has 9.5VDC on it while cranking? I would say you need a new solenoid, it should be full battery voltage, the voltage drop at the coil happens over the resistor wire going to the coil and the K-66 gets a full 12VDC from the pink wire off the steering column ignition switch. Even a battery starting to go bad should be able to generate 11.0VDC or better while cranking. I would be happier with a figure in the high 11VDC low 12VDC range. Try jumping to your horn relay terminal and starting it off that (on driver's side inner fender by vacuum tank.)
Yes the starter R terminal only has 9.5 VDC while I crank the engine. The battery voltage when I crank the engine drops from 13 VDC to 10.5 VDC. The Starter was just gone through and I had the solenoid replaced twice now because of this issue
Ralph.
Thanks Ralph for the help. I did buy a new amplifier BRD from Dave and the distributor is rebuilt by Crane corvette.
Dave says I have to have 10 VDC minimum at the R terminal and the battery voltage drops to 10.5 when cranking then just the wiring drops another volt and yet the positive cable is brand new and I cleaned all the grounds. Today I'm going to recrush the old ground wires and do some voltage drop measurements on the wiring but dang I'm out of ideas.
Does everyone elses battery voltage drop that low when cranking? Maybe I should replace the battery?
How good is the negative cable? Is it clean at the frame and battery connection? Is the ground cable that connects engine to frame large enough and contacts clean? Problems here can cause to much current draw and lower voltage also.
It looks good and I took it off yesterday and cleaned it and the frame. It's the stock original cable.
I'm reading on the internet that 10.5 cranking is good and that 1 VDC voltage drop at the starter is okay too...So how the heck can I ever get 10vdc to get the ignition to work?
Have you tried jumpering your battery to a running vehicle or an HD battery charger/starter and seeing if your car will start? That should at least give you a clue if it's truely a voltage issue.
