ls1 conversion engine mounts... rubber/solid?
Old Jan 30, 2012 | 12:01 PM
glarior's Avatar
glarior
Default ls1 conversion engine mounts... rubber/solid?
TO those that did the LS1 conversion... did you solid mount the engine or did you add rubber mounts? If you added rubber which ones?
I have a 80' with a LS1 and realized it is solid mounted to the car. You feel it every time you hit a bump.
Old Jan 30, 2012 | 01:48 PM
Garys 68's Avatar
Garys 68
In my corvette, I'm using solid motor mounts, rubber trans mount. That car is a convertible with sidepipes, so a little extra noise/vibration is no big deal.
On my 442, I used energy suspension poly mounts and rubber trans mount. Nice and smooth, no vibrations at all.
Old Jan 30, 2012 | 03:34 PM
glarior's Avatar
glarior
What do you feel when you hit a slight drop off in the road after a bridge?
Old Jan 30, 2012 | 07:00 PM
SuprJames's Avatar
SuprJames
I used poly, but as smooth as the LS's are I wouldn't hesitate going solid.
To ls1 conversion engine mounts... rubber/solid?
