Another trailing arm ?
Old Feb 4, 2012 | 07:08 PM
oledave60's Avatar
oledave60
Default Another trailing arm ?
I've done the search and didn't find an answer. I'm installing rubber bushings and I have the tool to press them in and flare. Got the first one in and compressed the rubber about as tight as I could get it with just a wrench. The washer is bevel side up, but there doesn't seem to be enough of the sleeve sticking through to make a proper flare. How far should the sleeve stick through to get a good flare? Thanks, Dave.
Old Feb 4, 2012 | 08:23 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Hi Dave-
If you don't have enough room to flare the sleeve then you do not have the bushing compressed enough. With the washer installed you'll see probably about 1/8" of sleeve from the bottom edge of the beveled washer.
If you look at the washer it has a bevel that the sleeve should be flared into and not stick out past the edge. Make sense? I hope so, maybe someone has a picture handy
Willcox
Old Feb 5, 2012 | 11:42 AM
tracdogg2's Avatar
tracdogg2
Dave,
If you'll drive to Garland I'll properly install them for you.
Mike
Old Feb 5, 2012 | 01:16 PM
0Willcox Corvette
Former Vendor
Originally Posted by tracdogg2
Dave,
Mike
Now there's an offer...
Old Feb 5, 2012 | 05:25 PM
oledave60's Avatar
oledave60
Well thanks for the kind offer and replys. I got them both in today with the help of some younger muscle, my son. They look good and now if I can get the spindle in without messing something up. Dave.
To Another trailing arm ?
