Help with steering Colume Please
Old Feb 5, 2012 | 08:35 AM
bobs76stingray's Avatar
bobs76stingray
Default Help with steering Colume Please
Hi guys,I have a 1976 Stingray and we all know just how ugly the vega style steering wheels are in this year.My question is,My steering colume is in need of replacing and I was wondering if there is another year Vette that will work in my 76?You know as far as the wiring harness hooking up correctly?Any help would be very appriciated,Thanks
Old Feb 5, 2012 | 08:48 AM
Jim Shea's Avatar
Jim Shea
Any standard (non-adjustable) or T&T Corvette steering column from 1969 through 1976 will fit your 1976 Stingray. Your "Vega" steering wheel is not tied to your 1976 column. You can install Corvette steering wheels from 1969-75 and 1977-82 to any of those Corvette steering columns.
You will need a steering wheel hub, upper horn contact, and horn cap to go with the all of the above steering wheels. If you decide on a T&T column you will also need the extension, telescope lock, upper and lower horn contact, and horn parts to go with the steering wheel.
Jim
Old Feb 5, 2012 | 08:57 AM
bobs76stingray
Thank-you for the help
Old Feb 5, 2012 | 09:21 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
It would be ALOT less headaches to just replace the wheel!!!
When you start getting into those columns, things get pretty tricky...ask me how I know!!!!!
Old Feb 5, 2012 | 09:25 AM
bobs76stingray
But to just replace the wheel,dont I have to buy an adapter hub kit to fit a 77-82 wheel?
Old Feb 5, 2012 | 12:49 PM
TimAT's Avatar
TimAT
No adapter if you use a GM Corvette wheel. The aftermarket ones will require an adapter
Old Feb 5, 2012 | 10:57 PM
Jim Shea's Avatar
Jim Shea
If you note my picture above. The steering wheel bolts onto the hub assembly with six screws. Your 1976 "Vega" steering wheel has a hub already molded into the steering wheel. So when you want a new steering wheel (Corvette OEM, or aftermarket) you have to come up with either the GM hub, or some aftermarket hub, or an adapter kit to adapt the new steering wheel to your 1976 steering column.
I think that some aftermarket suppliers have difficulty adapting their steering wheels to Corvette T&T columns. I had a new 1976 Corvette with a T&T steering column. As soon as the 1977 Vettes came out with the leather wrapped steering wheel I used 1977 parts as shown in the above blowup to install the much improved wheel on my 1976 T&T.
Do you have a T&T column or do you have a standard (non-adjustable) column? It makes some difference when you talk about adapting to your 1976 column.
Jim
Old Feb 6, 2012 | 05:25 PM
billsfan's Avatar
billsfan
If you have a T&T column, Corvette Central sells a kit (563066) that has everything needed to adapt to a 77-82 style wheel, without the wheel.
To Help with steering Colume Please
