72 rear window glass replacement?
Carefully soak everything for a few days with PB plaster and then try to take the screws out (mine actually came out easy)
lay the window flat and pour varsol on one side and let it soak for awhile to loose the sealer
Flip and do the other side
Now you need to gently pry the flat aluminum off without breaking or bending.
I took a pair of wood blocks (2"x4" x about 4") and clamped them to the window against the curves side and another set on the other side (against the flat out as far to the end as I could, opposite the other set) but allowing them to slide on the glass (a bit of grease helped)
Put a set of push clamps between the block sets and gently (slowly) applied pressure until the seal let go,
Tap the curved ends sideways with a wooden block (pins are angled)
More varsol into the open gap and then you can start to work your way around by hand.
Strip and polish the frame pieces
The new glass was about $100 from the local autoglass guy, I see the catalog companies are selling them also
It's only a single layer 1/8" thick, strange thing to handle, feels like it's gonna break
Patience letting the sealer loosen is the key
Mooser
Since everything is curved it made it hard to apply any pressure, that's when I got the idea of using the blocks and push clamp.
Mooser
Two things:
I got my screws out, but how did you get the pins removed?
Do I need to replace the liner on the inside of the frame or just slide the new glass into it?
Two things:
The tape from the old window will need to be removed and new tape added. It's the thinner stuff and finding it can be a challenge.
Here's the most overly complicated method I could come up with to replace mine using Urethane
http://forums.corvetteforum.com/c3-g...-urethane.html
HIH
Mooser
The suggestion of having a pattern made and set to be tempered is better. But that may not be done by a DOT approved source.
Here’s a possibility; Auto City Classics https://www.autocityclassic.com/2-do...glass-db1100t/
Green tint, made by a DOT approved manufacturer, and under $100. And, no, I’m not paid for endorsements. As many people I sent there I should get a residual…..
Steve O.
