Since last Summer my Vette began puffing some blue smoke on gear shifts and start ups, especially startups, I thought I should invest in the engine overhaul and change most of the stuff that wears out.
I would locate the machine shop that you are going to use and talk to them about your plans. Until the block is actually striped cleaned and measured you have no real idea what parts you will need. Ask around and find the most trustworthy machine shop.
What he said...don't know what the automotive machine shop business is like in your corner of the globe, but if you're absolutely sure you know of a place that can handle accurately boring/ honing your cylinders to within .0005" of the specified tolerance then the Summit kit would be a good choice because all the parts are there to completely freshen your engine. One thing that you want to be absolutely sure of before you begin is that your cylinders aren't already worn beyond .030" over standard bore (4.000") The last thing that you want to have to deal with from halfway around the world is a box of parts that you can't use. Northern Automotive also sells quality engine kits that you can more specifically tailor to your requirements that INCLUDE cam/lifter sets so you might want to look at them as well...as far as gaining power from the installation of an engine kit that would be more a function of camshaft selection and tuning (carb and ignition) but if everything is done properly you would definitely recover what your engine lost from being old and tired.
Thanks a lot for the info. I will ask my friend about this measurement possibility. About camshaft replacement... Does it mean I should also put on new cylinder heads and all such stuff to actually gain anything and make it work?
Why don't you have your friend help you and replace the valve seals, first. You can do it without pulling the heads, and it most likely will eliminate the smoke at startup and between shifts. Then you can spend your money on something else you were planning to do. That is unless your engine is really tired and truly in need of a rebuild. Good luck.
Duane
Replacing just the stem seals is another thing I was considering. I just thought perhaps I should give it a full overhaul. But there are no other signs of wear for this engine and last time the compression was okay like 2 years ago. Haven't noticed any power drop myself since then. It's an all original engine still with the Q-Jet carb and stuff. I don't know whether I should begin to pump it up for some extra HP or leave it all original...
I think I'd do a compression and leak-down before planning overhaul...
Coming from billa, this is sound advice indeed. Do your 'due diligence' before you go ripping into the engine. Again, to install any engine kit requires quite a bit of very exacting machine work, and all those shiny parts will be worth nothing if you can't get the prep/machine work properly done. Rebuilding an engine isn't that difficult; just a series of about 274 steps that all have to happen EXACTLY right...
All the valve seal suggestions are right on as is the testing. The Compression and a vacuum test. I didn't see your miles, the start up smoke is often the seals. If it's the guides, addressing the heads may be a cure.
If you want an engine that will make significantly more power, you would do better to build a new engine. Since yours is still working fine, either drive it until it actually needs help (fix valve seals, of course), or pull it and store it (original engine) and drop in a crate engine or one you build up.
If you aren't going to put that new power to regular use [you just want it], leave the engine alone. It seems to be serving you well 'as is'. {Hey! We'd all like to be with Angelina Jolie ...but that ain't going to happen, either.}
assuming you're going to rebuild/service your OE heads (w/ 76cc chambers).
I don't like most ADVERTISED kits because they seldom have the optimal pieces for YOUR individual needs. Many companies that supply machine shops put together kits according to buyers' wishes.
service your heads w/ fresh "Z28" springs.
L48 has dished pistons.
Replace pistons with Sealed Power p/n H618CP (has a small dome with a positive +3.5cc dome volume.
If deck does Not get cut, surfaced aka decked ... use felpro p/n 1094 head gasket.
a thirty over L48 w/ H618CP30 piston & 1094 gasket makes right at 9.8:1 scr. Decent cheap cam& lifter kit like summit K1104.
CF member dmaaero used H618CP in his build several years back.
