blowing headlights
Old Feb 7, 2012 | 07:13 AM
riverracer au's Avatar
riverracer au
Default blowing headlights
a couple of months ago i placed relays in the '72 for the sealed beam headlights
light output was unbelievable for only 37.5/50w globes
info from on here and http://www.danielsternlighting.com/t...ys/relays.html and the following wiring diagram
mounted on the rail up the front just where the hoses come
20amp circuit breaker, main heavier + wire (top left) from alternator/horn relay
brown socket (top cntr) from left headlight supplies the trip for the relays
new loom, so the original has not been cut into, sockets disconnected taped up
shared heavy earth lead with ring terminal to a clean earth point
tan wires low, green wires high
2 separate runs as relays had double out pins, right run l/h is separate to left l/h run except earth
problem is that i keep blowing the left hand low beam headlight
have replaced 3 so far, they only last 30min max...
have good voltage at socket, either straight to the chassis or thru the socket.
no problem with the high beams.... yet
i am at a loss to why?
Old Feb 7, 2012 | 08:19 AM
7T1vette's Avatar
7T1vette
Are the relays 'solid state' or contactor type? If not solid state, you could be putting a lot of stress on the filaments from current spikes when the contactors close. Not sure why just one bulb, but I suspect the others may be short-lived, too. (Is the bulb that is burning out the nearest one to its feed line?)
Perhaps a spike-suppressing capacitor on both the 'low-beam" and "hi-beam" output lines would solve your problem.
Old Feb 7, 2012 | 01:02 PM
speedreed8's Avatar
speedreed8
this is out of daniel stern article, like 7t1vette said you may have spiking, may need to check your alternator V.Reg. output w/ a meter while turning headlights on. dont know where you're getting your supply voltage from but its just a thought. goodluck.
"You may have heard that it's not good to take headlamp power from the alternator output because of "voltage spikes"; this is a myth. No voltage spikes are present in an electrical system with good voltage regulation, and any spikes that are present in a system with bad voltage regulation are present in equal magnitude across the entire system. If your charging system is "spiky", indicated by vehicle lamps that flash brighter and dimmer with the engine running at a steady speed, then you need to fix the problem that is causing the spikes! "
Old Feb 7, 2012 | 03:53 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
The original headlight switch is a mechanical contact type switch, and not solid state, so that is not the issue. I have been using relays for my headlights for years with no issues, something else is going on that is causing the headlight to blow.
Old Feb 7, 2012 | 05:00 PM
Shark Racer's Avatar
Shark Racer
The original switch doesn't carry anywhere near the voltage that a relay setup would, though...
...what kind of relay are you using?
Old Feb 7, 2012 | 05:31 PM
toddalin's Avatar
toddalin
Why just the left? If it is wired as indicate, the left and right see the same voltage. Are you sure this is really how it's wired?
This would seem to be a problem of over voltage so check whats coming out of the alternator.
Old Feb 7, 2012 | 05:35 PM
7t2vette's Avatar
7t2vette
The original switch carries the same amount of current that the relays do, and the reason to use relays is to deliver full system operating voltage to the headlights for maximum brightness. The wiring starts out with full voltage, but by the time it reaches the headlights, is has dropped. Light output is reduced at an exponetial and not linear rate with voltage drop, and the factory wiring methods, materials, and devices causes voltage drop by design.
I always use good relays, such as Bosch, or Tyco.
Some good tech here:
http://www.madelectrical.com/electri...adlights.shtml
And here:
Old Feb 7, 2012 | 05:56 PM
riverracer au
Shark - using Narva relays http://www.narva.com.au/products/browse/normal-open-4-5
7t2 - thats where i got my info from and from on this forum
only difference to the wiring diagram above is that i have from the relay, 1 wire direct to the left and 1 wire direct to the right instead of as shown...
relay had 2 output terminals so i used both
maybe i should join them together ?
will get the alt output checked by an auto electrician
Old Feb 7, 2012 | 06:36 PM
riverracer au
this is how i actually wired the lights
as you can see, a seperate wire to each side
Old Feb 7, 2012 | 06:47 PM
'75's Avatar
'75
If your wiring is messed up and powering both the hi and low beam for the left light at the same time it will probably overheat and burn out quickly. Those relays have a normally open contact 87 and normally closed 87a. If you are using both it could be causing the problem.
Old Feb 7, 2012 | 06:49 PM
7t2vette's Avatar
7t2vette
Your wiring diagram looks fine, should be no problem using both 87 terminals on the relays, they are afterall a common output. This is the relay you used?
First thing I would do is doublecheck your wiring, and then check your system voltage with a volt meter.
Old Feb 7, 2012 | 08:14 PM
riverracer au
that's the relay, Narva 12v 30A #68024
is it best to test the alt in the car under load or out of the car?
Old Feb 14, 2012 | 08:07 AM
riverracer au
UPDATE
i went to auto elec, and he said the alternator is fine, 14.2-14.4v under load.
if it was over voltage/spiking then other globes -blinkers, dash etc would be blowing as well.
the relay wiring i did checked out fine.
the only thing he commented on was the headlights open with a hard sudden stop.
there also aren't many makers of sealed beams any more, mainly cheap asian units,
which he thinks the filament is breaking with the hard stop now that it's got good voltage.
he suggested a few options,
1/ put a 3-5sec timer relay in so the doors open then the lamps light up
2/ tap into the door open switch to turn on relay only when fully up
3/ convert to halogen sealed beam (easy swap, more resilient)
4/ convert to halogen h4/h1 globes (harder swap)
how hard is the swap to option 4?
how much do the buckets/rear brace have to be opened up to fit the bigger back of the globe?
anyone got photo's? a link?
Old Feb 14, 2012 | 08:13 AM
Mark Riles's Avatar
Mark Riles
The H4 / H1 globes are a good options but I don't think they fit perfectly into the stock buckets and you would need to make room for the larger rear end of the globe by cutting the opening bigger in the backs of the buckets. Halogen would be your easiest solution. Next up would be the new housings, and to stay away from trying to overcomplicate the system with delays and limit switches.
Old Feb 14, 2012 | 01:59 PM
Shark Racer
7t2Vette - I understand the concept of relays, voltage drop, etc. My language was wrong.
What I meant to say was that the system where the SWITCH feeds the headlights does not carry the same voltage to the headlights. Much different electrical load to the headlights with a relay system than in the original switch system due to the voltage drop of the wires.
I've long been a proponent of headlight relay upgrades on older cars. I converted my 83 Ford and it was a "night and day" (sigh) difference.
riverracer au-
Option 3, I used Sylvania halogens in my truck, they worked well.
Option 4 - A company called... talbotco? I believe, aardvark industries, sells a cibie kit that I have in my 78 that uses the H4 style bulb. Look them up. It was a bolt in for me. A search for "talbotco" shows them on the first page for me.
Old Feb 14, 2012 | 04:04 PM
riverracer au
unfortunatly i need to buy australian approved globes/lens as our lights dip to the left
when we import cars over here, thats one of the first things they check
will try an get some sealed beam halogens first
thanks everyone
Old Feb 14, 2012 | 04:11 PM
7t2vette's Avatar
7t2vette
These are the exact H4 & H1 light housings I have been using for years with SilverStar lamps. They fit the headlight buckets with no mods. The low beams are plug and play, the high beams I made a short pigtail with male spade connectors on the end to plug into the factory plug.
low beams:
http://www.ebay.ca/itm/5-3-4-4000-H5...item4cfb5679d0
high beams:
http://www.ebay.ca/itm/5-3-4-H5001-H...item3594f56598
On my bench
The pigtails almost finished on the high beams
On the car
Halogens on the left, H1 & H4 on the right
Old Feb 14, 2012 | 04:43 PM
Shark Racer
7T2Vette - that looks great! I'm assuming you have relays in place in those photos?
I noticed a color difference once I finally upgraded my old Ford to relays.
To blowing headlights
