Rear differential leaking
Old Feb 7, 2012 | 06:10 PM
vtxvette's Avatar
vtxvette
Cruising
Default Rear differential leaking
I have an 80 corvette and need to replace the seals as it is leaking fluid. Not badly just a small amount when hot. My question is can I do the seal replacements without taking it out of the car?
Thanks for the help
Old Feb 7, 2012 | 08:20 PM
Bowerss2's Avatar
Bowerss2
nope.
Old Feb 7, 2012 | 09:11 PM
'75's Avatar
'75
Yes, and check the vent to make sure it's clear.
Old Feb 7, 2012 | 09:39 PM
Bowerss2's Avatar
Bowerss2
idk man i have an 80 and with the "batwing" i just took it out because it looked like a much bigger pita to try and do it in the car.
the cover is also the crossmember. because of this the bolts on the top would be very hard to reach. It would be possible if you unbolted the spring; removed the x member mounts (a good time to rebuild them anyway) unbolted the cover and removed it but i am telling you having done it it is easier to just pull the whole thing out it also makes torquing the cover way easier. Nothing is more frustrating then putting on a diff cover just to have it start leaking again esp if you have to go through all this nonsense.
ps i would also worry about trying to get the cover back on and everything lined up with the half shafts pressing down on the diff as the x member is no longer supporting it. The front diff mount might but again i see trying to replace the gasket in the car as a recipe for a headache.
Old Feb 7, 2012 | 09:45 PM
'75's Avatar
'75
Ya, if more than just the pinion seal is leaking it's better to take it out.
Old Feb 8, 2012 | 05:14 PM
vtxvette's Avatar
vtxvette
Cruising
Default Thanks for the help
I will be taking it out and rebuilding most of it along the way
Old Feb 9, 2012 | 08:42 AM
scorpion18z's Avatar
scorpion18z
Just got done doing that rebuild vtxvette. Take it out because you will have to remove the half-shafts to replace the seals. Also, plan on the half-shaft replacements (especially if they are original because of mushrooming upon removal. The pin will probably be worn when you are inside the pumpkin. I spent about $500 to replace the 3 seals, shafts and pin. Some kind of oil additive was recommended when re-filling, but I don't recall what it was.
Old Feb 9, 2012 | 08:44 AM
scorpion18z
Don't forget bushing replacement as well as mounting rubber...might as well go all the way while it is out.
Old Feb 9, 2012 | 08:53 AM
scorpion18z
[IMG][/IMG]
Old Feb 9, 2012 | 08:55 AM
scorpion18z
[IMG][/IMG]
Old Feb 9, 2012 | 09:53 AM
qwank's Avatar
qwank
where did you get those aluminum strut rods?
Old Feb 9, 2012 | 03:31 PM
scorpion18z
Believe it or not they were on the car when bought as original equiptment
Old Feb 9, 2012 | 05:10 PM
Bowerss2's Avatar
Bowerss2
Part of the gymkhana suspension package FE7 also has a 9 leaf rear spring and rear sway bar.
Old Feb 9, 2012 | 05:20 PM
scorpion18z
I really don"t know about the suspension package. I bought the car in Wisconsin last November and had it delivered to Florida, where I am in the process of a complete rebuild (painting and interior is all I have left to do)
Old Feb 9, 2012 | 05:27 PM
scorpion18z
I remember some numbers on the strut mounting brackets, but don"t remember what they were. I think you are right about the suspension. It was an option back in the day. This is news to me...good news I believe. I re-conditions all the rubbers on the suspension and mounting bolts. It is as tight as stiff as a drum, and with the new adjusting bolts, easy to adjust to driving conditions.
Old Feb 11, 2012 | 02:37 PM
vtxvette's Avatar
vtxvette
Cruising
Hey scorpion18. What do u mean by mushrooming. Basically everything is working properly hut looks old. I plan on replacing all bushings, shocks nuts and bolts. Also I do not have a lift and the car is drivable (a blast to drive) can thismbendonenonmjack stands and do I really need an impact wrench or will my ratchets do the job?
Old Feb 11, 2012 | 02:57 PM
tracdogg2's Avatar
tracdogg2
The stub axles are very soft. Instead of the metal wearing away on the tip it just rolls over and mushrooms outward. This will prevent the stub axle from sliding out thru the gear.
Mike
To Rear differential leaking
Old Feb 11, 2012 | 03:43 PM
scorpion18z
You will not be able to remove the short axles (and replace), the bearings, seals and pin (inside the differential) on jack stands. This work is best left to a drive-train mechanic who will have all the tools, lift and parts. He will also give you a warranty on the work. Don't forget to do the U-joints while you are tearing that rear-end down. I took the whole assembly out of the car (differential, short shafts, drive shaft, struts, and leaf springs while on jack stands. The impact wrench was not necessary; 6-point wrenches and sockets worked fine. I might have used a cheater bar...I don't remember. I then took the differential assembly down to the specialist along with the shafts to replace the press-in the U-joints. Assembly was easy with all the new bolts.
Old Mar 25, 2012 | 07:49 PM
vtxvette's Avatar
vtxvette
Cruising
Just finished did the entire rear rebuild new bushings shocks nuts bolts diff rebuild with seals carriage bushings etc... Also cleaned and re painted everything also new u joints went back together fine with original half shafts. Only problem is the rear is sitting at 27 inches with the front at 29 1/8 driver and 29 7/8 passenger. The rear looks right and drives great. But the front needs to be lowered as it was always high. How do I do that?
Asusual thanks for the help
Old Mar 25, 2012 | 08:08 PM
qwank's Avatar
qwank
first time I ever heard of the Gymkhana coming with aluminum strut rods
