Roller rocker arms
Old Feb 11, 2012 | 08:11 AM
RedZR's Avatar
RedZR
Default Roller rocker arms
Would adding 1.5 roller rocker arms to a
very 78 l48 produce any performance gains? The car has dual exhaust and i want to maintain the stock appearance but want a little more power
Old Feb 11, 2012 | 08:29 AM
jackson's Avatar
jackson
No perceptible gain.
Same goes for any 1.6:1 rocker regardless sliding or roller tip or full roller.
L48 has a little cam ... any improvement is a small percentage of base ... and here, the base is also quite small.
scummit & others sell good cam&lifter kits for about $100 ... K1102 or K1103 or similar would do nicely. Even then, seat-of-the-pants difference may only whet your appetite. Your OE intake & carb are more than adequate.
L48 has low compression via both dished pistons & large combustion chambers ... comp increase requires much more: time, labor, parts & $.
Old Feb 11, 2012 | 08:42 AM
Mark Riles's Avatar
Mark Riles
As a stand alone upgrade a roller tip rocker will do almost nothing you would notice. If you are really serious about wanting more power you have to devise a plan with a budget and base it on your timeline and your level of skill to accomplish the plan.
Old Feb 11, 2012 | 08:55 AM
Tom454's Avatar
Tom454
The only benefit to roller tip rockers as a standalone improvement is that they reduce the side loading on the valve stems & guides. I installed a set as a test and when I tore the engine down the new valves & guides I had installed had no perceptible wear. If your valves & guides already have a lot of wear on them, there would be no point in installling them unless you do a valve job. The next test is in progress... I installed a set of Rhoads hydraulic lifters which act a little like solid lifters at idle... a little loose (noisy)... and we'll see if that messes up the rollers.
To Roller rocker arms
