dumb question
Old May 13, 2002 | 11:19 PM
ykp53's Avatar
ykp53
Default dumb question
i might have this wrong, but dosen't a supercharger just basicly force air thru the carb. if so why wouldn't it be fesiable to do this with a electric fan also.
Old May 13, 2002 | 11:45 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: dumb question (ykp53)
The air going into your carb is at 1 ATM. pressure. A supercharger increases the pressure above atmospheric pressure, thus increasing the molecules of air and fuel which get to the engine...increasing horsepower. It's like putting twice as much fuel in each piston on each intake stroke. This is a very simple explanation. :) Chuck
Old May 14, 2002 | 02:29 PM
ykp53's Avatar
ykp53
Default Re: dumb question (Chuck Gongloff)
Okay so the supercharger compresses the air before forcing it thru the carb. does a blower do the same thing? what exactly does ram air do? does it offer any performance advantages over a stock carb? sorry for all the questions.
Old May 14, 2002 | 03:00 PM
Neo Fender's Avatar
Neo Fender
It's a little more involved than just adding air. You have to keep the air/fuel ratio constant. More air requires more fuel. A long time ago I read a story (Car Craft or Hot Rod Magazine) about a very old school hot rodder that used a can of freon under the hood as a poor man's nitrous oxide setup.
Old May 14, 2002 | 03:19 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
A blower and supercharger are the same thing, a turbo only differes on where it gets it's power. An electric fan ( blower ) is feasable but it's more efficient to run the blower off the engine than it is to suffer the power conversion losses in the altenator and the electric motor.
Ram air used the motion of the car to stuff more air down the carbs throat.
Nitrous oxide forces more air and fuel into the clyinders in a liquid form. ( it also cools the charge making it possible to really increase the amount of fuel / air you can stuff in.
It's, you see. all about shoving more air ( and fuel ) into the same space...wether you do it with a fan, ram air, or spray it in in liquid form...
[Modified by 427V8, 1:38 PM 5/14/2002]
Old May 14, 2002 | 03:44 PM
Garys '68's Avatar
Garys '68
I'll buy a hair blow drier and try it tonight.
If you want to get into details:
Most roots style superchargers mount the carb on top of the SC, so they suck more air through the carb.
I've seen centrigugal SCs setups that suck through, blow through, and many are mounted to fuel injection systems.
It takes A LOT of hp to generate 5-10psi, so it's easier to run it from an engine driven belt. You would need a very large electric motor to generate any significant boost. I heard about an electrical SC years ago, but I think it developed only about 1psi.
Ram air just uses an outside scoop to force mare air into the carb.
I've never seen any hp figures on ram air, but my opinion is that getting cold outside air probably increases hp more than any ram effect unless you have a huge scoop.
My $0.02
Gary
Old May 14, 2002 | 11:48 PM
Gary79's Avatar
Gary79
Default Re: dumb question (Garys '68)
the dual snorkel air cleaner on the 78 Pace Car and the 79 vettes accounted for a 5 hp gain in the L-48 engine rating, 190hp to 195 hp.
Old May 15, 2002 | 01:19 PM
Dwayne 76's Avatar
Dwayne 76
Is there any pictures on scoope's some have used on their cars? I'd be interested in trying a homemade solution. Though I still have to get the results of the K&N I just stuck on. Curious if there will be any improvment.
Dwayne
Old May 15, 2002 | 04:23 PM
Garys '68's Avatar
Garys '68
Default Re: dumb question (Dwayne 76)
There was a thread a few weeks back that documented the testing and design of the L88 hood. Short version: The highest pressure area that could be practically generated was at the base of windshield. So the L88s took their air from that location.
If you think about it, the drag caused by a scoop large enough to generate significant pressure at high speeds would probably cause more drag than the hp increase could make up for.
There must me some automotive or aerodynamic experts out there to comment on this.
Gary
To dumb question
