Well, It's Time To Post The Damage
Old May 13, 2002 | 11:43 PM
bence13_33's Avatar
bence13_33
Default Well, It's Time To Post The Damage
You guys have been asking for it, so here goes....you may want to sit down if you aren't already :). So here's the shopping list (*drum roll please*):
$300.00 Standard Bore 454 Block
$333.00 CAT 4340 Forged H-Beam Rods
$50.00 LS4 454 Cast Crankshaft
$550.00 Hooker Header Side Pipes
$450.00 "206" Heads, Ported, 2.19/1.88s, Bowls Blended, Gasket Matched
$75.00 Edelbrock Torker II Intake
$10.00 ARP Head Bolts (Donated By A Forum Member, THANKS!)
$30.00 454 Flywheel
$150.00 Lakewood Blow-Proof Bellhousing
$30.00 Short Style Water Pump
$10.00 Valve Covers
$20.00 Moroso Solid Motor Mounts
$30.00 2 Groove Crank Pulley, 2 Groove Water Pump Pulley
$41.99 Dyna-Gear Double Roller Timing Chain Set
$29.52 Clevite 77 Rod Bearings
$28.99 Clevite 77 Main Bearings
$17.99 Clevite 77 Cam Bearings
$46.99 Federal Mogul Moly Ring Set
$6.49 Mr. Gasket Grade 8 Balancer Bolt
$35.99 Mr. Gasket BBC Rebuild Kit (Gaskets)
$407.92 L2399F60 TRW Forged Pistons (Full Floaters)
$9.99 ARP Pro Flywheel Bolts
$23.99 Melling High Volume Oil Pump
$132.99 Comp Cams 10* Titanium Retainers
$99.99 Comp Cams Matching Double Valve Springs
$63.99 Comp Cams Solid Flat Tappet Lifters
$116.99 Comp Cams 294S Magnum Camshaft
$5.69 Plastiguage
$13.99 Moroso Steel Sleeved Oil Pump Shaft
$11.99 ARP Water Pump Bolts
$14.99 ARP Timing Chain Cover Studs
$4.99 ARP Oil Pump Stud
$56.99 ARP Main Studs (For Use With Windage Trey ; 2 Bolt Mains)
$164.99 Moroso Street/Strip Oil Pan (6qrts + 1 in filter)
$30.99 Matching Oil Pump Pickup
$67.99 Milodon Diamond Stripper Windage Tray
$25.99 Comp Cams 10* Matching Valve Locks
$146.99 Comp Cams Magnum 1.72 Roller Tip Rocker Arms
$94.99 Comp Cams 3/8" Magnum Pushrods
$18.99 Mr. Gasket Steel Shim Head Gaskets
$20.99 Moroso Lifter Valley Oil Shield
$8.99 ARP Motor Mount Bolts
$7.99 ARP Frame Mount Bolts
$3.99 ARP Cam Bolts
$33.99 ARP Oil Pan Stud Kit
$21.99 ARP Stainless Steel Valve Cover Bolts
$19.99 ARP Stainless Steel Intake Bolts
$34.99 Stage 8 Locking Header Bolts
$6.69 Proform Chrome Dipstick
$8.99 Mr. Gasket Hi-Flow 160* Thermostat
$22.99 Mr. Gasket Chrome Holley Throttle Linkage Plate
$34.99 Mr. Gasket Copper Header Gaskets
$13.99 Moroso Roller Pilot Bearing
$9.99 Moroso 19-21lb Radiator Cap
$51.99 Holley 60gph Chrome Fuel Pump (Need A Bigger Pump :) )
$6.99 ARP Pressure Plate Bolts
$14.99 ARP Lightweight Fuel Pump Pushrod
$49.99 ARP Pro Bellhousing Studs
$259.99 Centerforce Dual Friction Clutch
$32.99 Centerforce Throwout Bearing
$19.99 Moroso Solid Tranny Mount
$13.99 Mr. Gasket Adjustable Ball Stud
$45.99 Moroso Rubber Valve Cover Gaskets
$60.00 Rebuilt AC Delco Alternator
$491.99 Be Cool Aluminum Radiator
$61.99 Accel 8mm Plug Wires
$75.00 Block Cleaned/Magnufluxed
$30.00 Crank Cleaned/Polished
$193.00 Bore +.060"
$120.00 Head Cleaned/Inspected
$25.00 Install Cam Bearings
$175.00 Balance The Engine
$33.00 Clean/Resurface The Flywheel
$12.11 Freeze Plug Kit
$12.00 Machine Heads For Teflon Valve Seals
$21.28 Teflon Valve Seals
$146.65 Alternator, Power Steering Brackets & Bolts
$33.93 Radiator Hoses
$16.99 Mr. Gasket Holley Dual Feed Line
$15.00 Misc. Nuts & Bolts From Lowe's
$120.00 (2)Heli-Coil Kits
$15.00 Gas Lines
$6.00 Octane Boost
$10.00 Spark Plugs
$25.00 Head Assembly
$12.00 Case Of Oil
Which gives me a grand total of $6,059.79 :sad:. Jeez oh man, another $4,000 or so and I could of had a 540 :(. Oh well, it's only money :lol:. This has truely been an experience that I will remember for the rest of my life. It's definitely more than I had originally set out to spend but you gotta pay to play I guess. This is why this engine has taken me nearly a year to build. The above is the reason why I will be taking a nice 500 + mile break-in period.
P.S. I just checked to see if my hood is going to close....it won't. You might as well tach on another $500 for an L88 hood and $200 for a Victor Jr. Intake. I know I could probably squeeze a drop-base air cleaner under but this Torker II is already going to be killing too much performance. I might as well get the hood and an intake to match my setup.
Old May 13, 2002 | 11:50 PM
Chris Fowler's Avatar
Chris Fowler
Cruise-In IV Veteran
St. Jude Donor '03-'10
Default Re: Well, It's Time To Post The Damage (bence13_33)
:eek: :eek:
Where's a little fainting smiley?!?
Old May 13, 2002 | 11:55 PM
Don Schuette's Avatar
Don Schuette
Bence: Don't forget about all the future gasoline bills! As you've already found out, they love to drink fuel. As I say, "You only live once, enjoy it."
Great Job.
Don
Old May 14, 2002 | 12:00 AM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: Well, It's Time To Post The Damage (Don Schuette)
Don't scare us like that, I thought you blew up the motor already. I do share your pain in the spending department. As for gas bills, don't even go there.... :cry
Old May 14, 2002 | 12:11 AM
bence13_33's Avatar
bence13_33
Default Re: Well, It's Time To Post The Damage (C3 Shark Tank)
C3 Shark Tank:
I'm sorry, I didn't realize the title was so misleading. I actually haven't fired it up since I last drove it (Saturday). It's been raining here Sunday and Monday, hopefully it will stop so I can take her out on another short trip tomorrow.
On a lighter note I have a set of JCL spiral baffle inserts coming in about a week or so. I'm going to put them in just like they come, but if they quiet the car down too much I'm gonna have to start drilling some holes :). I want the loudness to be in between open headers and a "normal" big block exhaust. Personally I'd run it on open headers if it weren't for the neighbors :).
Old May 14, 2002 | 12:18 AM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Wait to you buy a FI set up one day. :cry :cry I've learned never to make a budget. It just doesn't work. :yesnod:
Old May 14, 2002 | 12:24 AM
Bob Turner's Avatar
Bob Turner
Bence,
Looks VERY familiar!! I think I am up to $6,800 or so and I am NOT DONE- that's the scary part!!
Bob :cheers:
Old May 14, 2002 | 12:25 AM
Indy Year 25's Avatar
Indy Year 25
Not to mention tires!
Old May 14, 2002 | 12:27 AM
Detroit Vette's Avatar
Detroit Vette
That's more than i made this year :lol: Isn't unemployment grand :U
Old May 14, 2002 | 12:40 AM
C3 Shark Tank
I'm sorry, I didn't realize the title was so misleading. No biggie, I soon realized by damage you meant to the bank account. :jester
I seriously doubt you'll have to do any drilling, the pipes will be plenty loud...unless you're deaf already :D You're going to really like the baffles, I'll have video/sound by the weekend if all goes well.
Old May 14, 2002 | 12:44 AM
trw's Avatar
trw
Shane
I lifetime experience, can you wipe the grin off yet.
Best of luck.
Terry
jdunne's Avatar
jdunne
Bence,lucky your engine doesnt have a carby or it could have got really expensive!!!!!!!...sorry,i couldnt resist when you seem to have listed everything except the carby.......you should try doing what you have done here in Australia,everything costs twice as much and is harder to get.....john :chevy
Old May 14, 2002 | 01:28 AM
bence13_33's Avatar
bence13_33
Default Re: Well, It's Time To Post The Damage (Budman78)
Budman:
Probably not going to happen :nonod:. I love the simplicity and sound of a carbureted engine. FI just isn't for me....although if I were to go FI it would be mechanical fuel injection :D.
Terry:
Honestly....no I can't wipe the smile from my face :). I just keep thinking about whenever I tapped that gas and it snapped my head back and threw me to the back of my seat. I can't wait to take her out for another spin.
jdunne:
Actually my Holley 850 Double Pumper was donated to me by a fellow forum member (thanks Steve, I love the carb!).
Old May 14, 2002 | 02:35 AM
Maurice's Avatar
Maurice
You didn't spend as much as I thought you would have, plus you went to sidepipes which added on a bit of money. I was expecting the total to be closer to 10K for some reason. Good Job! I cheated getting my BB. :D
[Modified by Maurice, 8:35 PM 5/13/2002]
Old May 14, 2002 | 06:34 AM
Steve Adkins's Avatar
Steve Adkins
Default Re: Well, It's Time To Post The Damage (Maurice)
Great job! Money well spent. It is good to hear that there is still guys out there that pays attention to the finer details and don't get cought up in just the performance parts alone, for example all of the bolts you bought that shouldn't be neglected. :cheers:
Old May 14, 2002 | 07:19 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: Well, It's Time To Post The Damage (Steve Adkins)
You're a brave, brave man Shane. It took a lotta guts to post that list. I'm not sure I coulda.
I have a feeling that you'll be cranking out more HP than a crate engine so the $$ spent will be well worth it. You've got quality parts, some extras here & there(Oil pan, sidemounts, radiator etc) so I think you're ahead of the game. I definitely want to drive up there one day this summer just to hear this baby!
BTW, there's a Dyno near me that charges $75 for the first run and $65 for each additional run.
[Modified by 1970 Stingray, 6:21 AM 5/14/2002]
Old May 14, 2002 | 07:28 AM
Steve Straus's Avatar
Steve Straus
Right there with ya buddy. Remember that nice hood that I spent a long time sanding and prepping and masaging, and loving, saying things to it like "You're a naughty hood, naughty". I'm going to have to replace it with an L88. After thinking about it, snuffing my engine with a Torker II would be a mistake.
To Well, It's Time To Post The Damage
Old May 14, 2002 | 07:33 AM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Shane, that's actually not "too" bad for what you have at the end result :) . That's a lot of motor for the money :yesnod: ! Tighten down the seat brackets and enjoy the ride :D .
Old May 14, 2002 | 07:37 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Default Re: Well, It's Time To Post The Damage (SmokedTires)
Nice pic Mike....love the paint & TT2's! Been looking forward to new pics.
Old May 14, 2002 | 07:41 AM
SmokedTires
St. Jude Donor '05
Default Re: Well, It's Time To Post The Damage (1970 Stingray)
Thanks Stingray, I've been wiating foir a nice shot too ;) .
