76 Clutch Replacement
Old Feb 12, 2012 | 03:25 PM
Greg Delfino's Avatar
Greg Delfino
Cruising
Default 76 Clutch Replacement
I am having difficulty moving the drive shaft yoke forward to remove the driveshaft. I have unbolted the differential carrier, unbolted the U bolts at both ends of the drive shaft and when I go to push it forward into the transmission, NO FORWARD MOVEMENT. What is the Hold up??
Thank you in advance.
Greg
Old Feb 13, 2012 | 11:44 AM
MelWff's Avatar
MelWff
Have you tried gently tapping the yoke with a hammer?
Old Feb 13, 2012 | 07:38 PM
Greg Delfino
Cruising
Yes I have and there still is no forward movement. Is it possible to pry the Universal joints out of the Yoke?
Old Feb 14, 2012 | 01:30 PM
MelWff's Avatar
MelWff
yes you can try putting a large screwdriver/prybar between the front yoke and it's ujoint to break the ujoint free and hopefully push the yoke in.
To 76 Clutch Replacement
