1977 courtesy light mounting bracket
Old Feb 14, 2012 | 02:02 PM
jjman's Avatar
jjman
6th Gear
Default 1977 courtesy light mounting bracket
I can't see a way to logically install the courtesy light mounting bracket under the driver's side dash. Does anyone have a pic, or good explanation?
Old Feb 14, 2012 | 02:07 PM
wan2run's Avatar
wan2run
Welcome to the forum! My first piece of advice would be to purchase the AIM (Assembly Instruction Manual) for your year car from one of the vendors here. It shows how every piece of the car was put together on the assembly line.
Old Feb 14, 2012 | 02:22 PM
77C34SPD's Avatar
77C34SPD
bulb goes toward hood release,mounts to the back of the dash.You should see a small plastic boss with a hole for a phillips screw.
Old Feb 14, 2012 | 02:25 PM
jjman's Avatar
jjman
6th Gear
Thanks, I'm gonna look for that later.
To 1977 courtesy light mounting bracket
