Front Crossmember Dent removal tool
Old Feb 15, 2012 | 09:55 AM
jetjockey's Avatar
jetjockey
Default Front Crossmember Dent removal tool
Have tried to contact a fellow that was"renting" his a couple years ago. No response. Does anyone have this tool that would be willing to rent it to me? I promise to return it and take good care. Would also consider a purchase of a used one if need be?
Does this belong in the F/S section? If so, sorry!
Dan
Old Feb 15, 2012 | 11:27 AM
rugerm44's Avatar
rugerm44
What dose it look like.I can probably make one.
Old Feb 15, 2012 | 12:08 PM
jetjockey's Avatar
jetjockey
http://forums.corvetteforum.com/c3-p...pair-tool.html
Link is to old thread here that has a picture, best I can do.
Can't find the tool at any of the suppliers, seems to be discontinued.
Dan
Old Feb 15, 2012 | 12:28 PM
Buddy1980's Avatar
Buddy1980
Default Dent removal tool
FWIW, I too had a badly dented lower front crossmember, but instead of trying to remove the dent, I simply took a chisel and removed the lower dented portion, flattened the removed piece to make a pattern, traced the pattern onto a nice piece of .120 thick steel sheet which is thicker than the original piece, then mig welded the new piece onto the frame. When I finished, it looked original but is now thicker and will not dent very easy like the factory piece. I did this with the frame out of the car, but if your car is all together I think you could still do this, although it would be a little tougher working from underneath the car. This took me one afternoon to accomplish and cost nearly nothing. Good luck.
Old Feb 15, 2012 | 01:48 PM
Mashman's Avatar
Mashman
VolVette has it on their website. http://www.volvette.com/TL80.html
I too would be interested in renting it.
Old Feb 15, 2012 | 01:55 PM
Mashman's Avatar
Mashman
Here's a picture of the tool -
I havn't used the tool, but guessing that the part with the weld nut goes into the crossmember. The bridge goes across the main structure of the crossmember, and the bolt screws into the weld nut, and pulls the dent down.
I'm guess that maybe the shims are to keep the inside part in a certain location? Or to keep the whole thing from moving?
Old Feb 15, 2012 | 02:02 PM
Vette5.5's Avatar
Vette5.5
This is the way I'd go, but would use a cut off wheel. A little grinding, and you'd never know the repair was ever done.
Old Feb 15, 2012 | 02:22 PM
Alan 71's Avatar
Alan 71
Hi,
I believe the fellow who designed and made the tool is Terry Fiala.
Google.... Terry Fila Corvette Tool and you'll see T.J.A. Tooling Inc.
He designed the tool about 5? years ago.
Regards,
Alan
Old Feb 15, 2012 | 04:39 PM
Mooser's Avatar
Mooser
Bob68 had stated he had a tool willing to rent
That was a little while ago but worth checking
So far I've avoided rolling past the firewall so I'm holding off for now
Mooser
Old Feb 15, 2012 | 04:46 PM
chevygod's Avatar
chevygod
Info posted above on use of this tool looks about right from looking at the pics, but does anyone have "official" instructions on how to use this tool?
edit, Searched for the info posted by Alan and found a back door link to this... same thing?
http://forums.corvetteforum.com/c3-p...-corvette.html
Best,
Tom
Last edited by chevygod; Feb 15, 2012 at 04:51 PM. Reason: found something more...
Old Feb 15, 2012 | 05:23 PM
Alan 71's Avatar
Alan 71
Hi Tom,
Yes, that's the fellow and tool I was thinking of.
Regards,
Alan
To Front Crossmember Dent removal tool
