throttle bracket repalcement
Old May 14, 2002 | 11:18 AM
mncus11's Avatar
mncus11
Default throttle bracket repalcement
I just changed all of the stock components like the intake manifold and quadrajet carb, wiht edelbrock performer series carb and intake. WHat do i do with the throttle cable bracket?it is different because of the holes that the carb uses. THe car is a 71 350 and the bracket pinches the cable. THe bracket also has a hole for the carb stud to run through and a pin to hold the bracket from swiveling. the new carb uses the opposite configuration with reguards to the holes. any suggestions on throttle brackets? If anyone has a pic of the set up im talking about please show pics. thatnks
Marc
Old May 14, 2002 | 12:46 PM
tsw71's Avatar
tsw71
Default Re: throttle bracket repalcement (mncus11)
The original will not work as is. I just installed the "Lokar" throttle cable and bracket. It cost about $50 from Summit. You can also get other cheaper brackets. Here is a pic of the Lokar setup on my Holley. It is infinitely adjustable and will work on any carb.
Old May 14, 2002 | 08:46 PM
mncus11's Avatar
mncus11
Default Re: throttle bracket repalcement (tsw71)
but wht do i dot if i have teh stock cable?? it pinches it, the cable is not like yours
Old May 14, 2002 | 08:55 PM
Aaron-74's Avatar
Aaron-74
"I just installed the "Lokar" throttle cable and bracket. "
read....
Old May 14, 2002 | 08:58 PM
mncus11's Avatar
mncus11
Default Re: throttle bracket repalcement (Aaron-74)
did u have the stock line what year is your car mine is a 71 the throttle cable does not attach to the bracket the same way (with bolts), it is pinched between metal? is there a bracket that accomidates this?
Old May 14, 2002 | 09:00 PM
mncus11's Avatar
mncus11
ps nice motor mine looked almost exactly the same way about a week ago
Old May 14, 2002 | 09:02 PM
Aaron-74's Avatar
Aaron-74
Thanks..
Mines a 74. The Edlebrock Performer I had worked just fine with the stock bracket. I used an Edelbrock throttle cable connector on the carb though. On the throttel lever.
Old May 14, 2002 | 10:07 PM
BSiegPaint's Avatar
BSiegPaint
St. Jude Donor '06-'07
I don't know if this will help, but I just fabbed a piece out of an old muffler clamp (necessity is the mother of invention...). Moved my stock bracket back a bit with the piece and bolted it down. Granted I have a Holley instead of an Edelbrock, but it sounds like the problems were similar.
[Modified by BSiegPaint, 7:43 AM 5/15/2002]
To throttle bracket repalcement
