Is this engine a tire smoker in your Vette?
I am finding that it isn't in mine - I am a little disappointed in the amount of torque (pull) that the car has.
What has your experience been with this engine?
Too many questions. Can a 330 HP engine break tires loose? Yes. Yours might not be for reasons other than the engine. Who timed and tuned your engine? What intake, carb, transmission, TC, exhaust?
I have a 430HP 383 stroker in my '82 with a 700R4, 3:73 gears and a 2400 stall speed converter and mine will go down the street sideways as long as you want it to in all 4 gears. I agree that there is more than the engine involved with how quick the car is. It is a precise balance of all the drivetrain components that make a difference, not just engine HP!
I have the 330 hp GM Performance 350 HO in my '80. Yes, it is a tire smoker, but it didn't always run that well. It took a few years of tuning and other car mods to dial it in. I am getting at least 330 hp from it now. It put almost 300 hp to the rear wheels through the original BW Super T-10 4-speed. The lower 1st and 2nd gears of the Keisler RS500 5-speed transmission makes it even quicker off the line than with the Super T-10.
You need to tell more about your car to narrow the problem down. I'll look for the list of things I did that got my HO to its current output.
Ive had that engine in 2 cars not vettes though. one came in a 65 chevelle I bought it couldnt get out of its own way it had the wrong plugs,carb was jetted wrong,and timing curve was wrong I tuned ti to the GM specs and it was night and day difference. I have had the 385hp fast burn engine also also excellent when properly tuned.
My experience with the GM crate engines has been that you need to make sure that they are optimally tuned and have the usual aftermarket goodies (ie headers, dual exhaust etc) to maximize the potential. With all that said, remember that the GM crate engines are rated as GROSS, not NET, HP like al cars since 1972. Unless the GM crate engine is currently instaled from the factory in a vehicle (LS7 crate engine is rated at 505 Net HP) , the HP rating is gross. A 330 Gross HP crate engine is roughly 275-285 Net HP, and of course much less for RWHP. Probably not too hard to get to 290-300 RWHP with fairly easy mods!
You really need to optimally tune your GM Performance crate and surround it with aftermarket goodies. The add-ons that gave me the most improvement were full-length headers, true dual exhaust with an H- or (better yet) X-pipe, and high flow mufflers. The Vortec heads and GM low-profile intake flow really well on the intake-end, but you need to modify your exhaust from stock to improve the flow on the exhaust end.
My thread with my most recent dyno results and tuning I did to get nearly 295 rwhp from the 330 hp HO:
The HO also provides a good foundation for a 400+ hp engine by adding the GM Performance LT1 Hot Cam kit and Comp Cam springs (not the springs that come with the kit). That is my next major project.
