Quadrajet 4MV help needed.
Old Feb 17, 2012 | 08:41 AM
thomasanonymous's Avatar
thomasanonymous
Default Quadrajet 4MV help needed.
I am rebuilding the carb on my '74 4 speed. I can't find info on the part number on it. 7045626. I'm not sure if this is the original carb. I need to know the float level height. Thanks!
Old Feb 17, 2012 | 10:58 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Your rebuild kit should tell you the float setting.
This is good.
Old Feb 17, 2012 | 11:05 AM
thomasanonymous
Nope. 7045626 is not listed on it.
Old Feb 17, 2012 | 11:31 AM
Peterbuilt's Avatar
Peterbuilt
Can't find any info on your carb but my 74 has a 7044207 and the float is set to .375"
You might start there.
Old Feb 17, 2012 | 11:34 AM
thomasanonymous
Thanks. I appreciate you taking the time to look that up. I had a feeling it was 3/8's. I set it to .250 and it ran like poop and smoked. Thanks again. Tom
Old Feb 17, 2012 | 11:46 AM
Vette5.5's Avatar
Vette5.5
If you're doing any kind of work on Q-Jets, the mentioned Doug Roe book's a good one. Can also contact Q-Jet guru Lars Grimsrud v8fastcars@msn.com. If anyone can help, he's the guy.
Old Feb 17, 2012 | 11:54 AM
Mike Ward's Avatar
Mike Ward
This is not the original carb, it's from a '75 Chev of some sort with auto trans.
Old Feb 17, 2012 | 11:59 AM
Mashman's Avatar
Mashman
Are you sure the '626' isn't '526'? If so, it's a 1975, California, Chevy, with auto.
Old Feb 17, 2012 | 12:03 PM
thomasanonymous
Thanks guys.
To Quadrajet 4MV help needed.
