Haunted windshield wipers?
Old Feb 17, 2012 | 06:54 PM
Turbotrad's Avatar
Turbotrad
Default Haunted windshield wipers?
My wipers always hit the wiper door before it opens.
I tried to adjust the wiper door limit switch plunger and nothing changed.
I then adjusted the plunger all the way out so that with the wiper door fully open the plunger wasn't even touching the limit switch. The wipers still operated.
While the wipers were operating I pressed the limit switch in and out and it didn't change the operation. The wipers kept on wiping away.
Is there something I'm not understanding here? How can the wipers operate regardless of the condition of the limit switch?
Old Feb 18, 2012 | 07:43 AM
Alan 71's Avatar
Alan 71
Hi T,
I'd think it means the switch isn't working. Something is stuck inside. It thinks the button is pushed even when it's not.
BOY! That's a very 'high tech' reply!
Any chance of prying the switch open to see what's in there?
I did that to one of my headlight door switches with success.
Regards,
Alan
Old Feb 18, 2012 | 11:35 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Alan 71
...I'd think it means the switch isn't working...
I think you're dead on.
Old Feb 18, 2012 | 03:27 PM
Turbotrad's Avatar
Turbotrad
It's confusing because the wipers still operate.
If the switch IS bad I wonder how the wipers can still run.
Old Feb 18, 2012 | 06:36 PM
patraw03's Avatar
patraw03
If there is a short, it would still allow the wipers to run, if that is the case
This would be the best bet because a short would be easy to fix, run a multimeter you should be able to find the problem.
Old Feb 18, 2012 | 07:00 PM
wombvette's Avatar
wombvette
You can unplug it.
If it still works someone has wired around it or something is wrong inside the motor.
Old Feb 19, 2012 | 06:05 PM
mark6669's Avatar
mark6669
Unplug the switch connect ohm meter across switch terminals push button see if it opens and closes it sounds like it is stuck closed should be a very quick and easy test.
Mark
Old Feb 21, 2012 | 02:16 AM
Turbotrad's Avatar
Turbotrad
I think someone might have wired around it. When unplugged the wipers still operate.
I'll have to investigate, although I could leave it as is and just open the wiper door separately using the bypass switch under the dash. I just get curious and chase problems. I think it's because I own a 43 year old car with no written history of changes/modifications.
To Haunted windshield wipers?
