How do I build this?
Old May 14, 2002 | 02:41 PM
jerryjfunk's Avatar
jerryjfunk
Default How do I build this?
Let's say I want to build a 383 stroker out of my 350... I would use a 400 crank, right? Then what from there, do I use 350 rods or a special length? If anyone knows where I can find good instructions on doing this, I'd apreciate it! :)
Thanks,
Jerry
Old May 14, 2002 | 10:51 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: How do I build this? (jerryjfunk)
Go to http://www.speedomotive.com they specialize in stroker kits (only $460 for a crank kit). Basically, you need a 400 crank and rods. You can get a new stroker crank for about $160 that you don't have to do anything to (a 400 crank will require machining). You will also need stroker pistons but they are quite common. A 400 crank requires an externally balanced flywheel/flex plate and harmonic balancer.
Old May 14, 2002 | 11:04 PM
Gary79's Avatar
Gary79
Default Re: How do I build this? (burners)
I'm no expert, but doesn't part of the block have to be machined to that the rods clear???? pull up American Speed in Moline,IL. they advertise a 383 with close to 500hp on pump gas, a streetable engine. someday i'm gonna give'm a call,drive up the river and pick one up!!! til then i'll be happy with my souped up, rebuilt L-48.
Old May 15, 2002 | 02:09 AM
jerryjfunk's Avatar
jerryjfunk
Default Re: How do I build this? (Gary79)
As usual, the forum is the absolute best place to get information! Thanks everyone, I really appreciate your help! :cheers:
For anyone else interested in building a stroker, Lars emailed me with some helpful info; I'll post it here.
You can build the 383 in one of 2 ways. You are correct that you run the
350 block with a 400 crank. You have also realized that if you hang a set
of stock rods and pistons on this combo, your pistons will get pushed up
above your deck height.
The first option, and the least desireable, is to run the 400 rods (5.565
length) with a 350 piston. This does not produce optimum crank angles,
and I've seen a lot of premature bearing wear on engines constructed like this.
The better option is to run the 350 rods (5.700 length) with a custom
piston. Every major piston manufacturer makes a piston for this application
due to its popularity. I've been using Speed Pro. With this combination,
you must clearance the block a little to keep the rods from hitting the
block in the lower cylinder areas and in the cam area. This combination
of parts has proven to be reliable, with excellent longevity.
Lars
CorvetteForum.com
Denver
Thanks,
Jerry
Old May 15, 2002 | 03:13 AM
jackson's Avatar
jackson
Jerry's info from Lars mirrors my experience. Whatever combo you chose, and AFTER you've fitted it into block & clearanced everything, you must have the rotating assembly balanced at machine shop ... cost $100 to $200 for balancing. Also, if using GM 5.7" (350) rods ... expect to grind (cam-clearance) rods to prevent rod-to-cam interferance. Don't bother with an old 400 crank ... get an aftermarket one. Most CAST 383/400 cranks are Externally balanced and require a 400-type damper & flexplate. Many FORGED 383/400 cranks are Internally balanced and require 350-type damper & flexplate. Also, forged/internally balanced cranks often require less machine work when time to balance ... so the higher purchase-price of a forged-internal balance crank MAY be offset by NOT requiring purchase of 400-type damper & flexplate. Don't bother paying for a PRE-balanced rotating assembly ... pull it outa block after you've fitted it and then balance. Also, you must verify if you block/heads have been decked/surfaced ... BEFORE you order parts ... so you can calculate compression ratio ... and acquire pistons w/ proper CR. See links for pics of cam-clearanced 5.7" GM rods.
http://www.imagestation.com/picture/...0/fdbd8628.jpg
http://www.imagestation.com/picture/...5/fdbd8621.jpg
http://www.imagestation.com/picture/...d/fdbd861b.jpg
Old May 15, 2002 | 03:47 AM
jerryjfunk's Avatar
jerryjfunk
Default Re: How do I build this? (jackson)
Thanks for the additional info.
There isn't any way of getting around grinding the rods? Doesn't that make them weaker?
So, are you happy with your engine? What kind of CR do you have, and what kind of hp/torque are you making, roughly?
Thanks,
Jerry
Old May 15, 2002 | 09:43 AM
ZD75blue's Avatar
ZD75blue
i think the pan rails also have to be ground a little... i think one rod bolt hits, forget tho... been awhile since i have used this part of the old brain :jester
Old May 15, 2002 | 12:09 PM
Paul 75 L82's Avatar
Paul 75 L82
Default Re: How do I build this? (ZD75blue)
Buy a Chevy High Performance maganize and find a Summit catalog. from the both of them you can find anything.
Old May 15, 2002 | 02:02 PM
The Dude's Avatar
The Dude
DON'T GRIND ON THE RODS! If you are having rod-to-cam clearance issues get a small base circle camshaft. Or use different rods. BUT DON'T GRIND THE RODS!
Old May 15, 2002 | 07:17 PM
Strike3's Avatar
Strike3
I think Comp Cams makes a special small diameter cam to prevent cam interferance. Check them out when it comes time to pick a cam.
To How do I build this?
