gasga-cinch,anybody use this stuff
Old May 14, 2002 | 02:55 PM
derv3tt3's Avatar
derv3tt3
Default gasga-cinch,anybody use this stuff
Edelbrock recommends using gasga-cinch for intake manifold gaskets.If you use anything what do you use?Thanks :rolleyes:
Old May 14, 2002 | 02:59 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default Re: gasga-cinch,anybody use this stuff (derv3tt3)
I use it on my fuel pumps and goose necks. It's pretty good stuff. Seals well and also help to hold the gasket in place while mounting. Never used it on an intake though. Don't see why it wouldn't work. You apply it to a gasket and let it dry(5-10min). Once dry, its sorta like rubber cement.
Old May 14, 2002 | 04:47 PM
vettesite's Avatar
vettesite
I used it on my intake, just like the Edlebrock instructions said and it worked well. I used a product made by Permatex instead of Edelbrock's product. Small blue/white/orange can of red stuff that comes with a brush built in the top. It's sold at any auto parts store. I use it on almost all my gaskets and none of them leak.
Old May 14, 2002 | 04:50 PM
Zack Wenning's Avatar
Zack Wenning
I'm with the rest of them, It works great!
Old May 14, 2002 | 04:52 PM
fauxrs's Avatar
fauxrs
used it on the rear diff cover just recently in my rear end rebuild - no worries, its the best.
Old May 14, 2002 | 05:02 PM
C3 Shark Tank's Avatar
C3 Shark Tank
Default Re: gasga-cinch,anybody use this stuff (fauxrs)
Add another satisfied customer. Haven't used it on an intake, but have used it everywhere else.
zwede's Avatar
zwede
Only downside is that if used with paper gaskets, they are almost impossible to get off. I used it on the timing cover gasket and had to scrape it off with a razor blade.
Old May 14, 2002 | 07:45 PM
Desertvette's Avatar
Desertvette
I use Valco Hylamar gasket dressing and maker. Made under licence to Rolls Royce. I've bought it at Pep Boys.
This is the only stuff that has worked succesfully for me on auto trans cover gaskets to prevent leaks. I use it on all my engine gaskets that i use sealant on. It also comes apart pretty good without destroying the gasket and not hard to clean up
LOL BOB
Wrencher's Avatar
Wrencher
Default Re: gasga-cinch,anybody use this stuff (zwede)
I use it a lot. First used it on VW engine cases that have no gasket. It's a bear to get off, though. I also use 3M weatherstrip adhesive and hi-temp oil resistant silicone form-a-gasket. The three pretty much cover my needs.
Hans
Old May 15, 2002 | 12:43 AM
derv3tt3's Avatar
derv3tt3
Default Re: gasga-cinch,anybody use this stuff (Wrencher)
Thanks for all of the replies,i bought a can tonight.The last 2 times I removed the intake the bottom part of the gasket against the head had oil underneath,thats why the question.What about the front and back of the intake? I bought Permatex gold but not sure about using it. :chevy
To gasga-cinch,anybody use this stuff
