Water temp meter not working
Old Feb 18, 2012 | 11:44 PM
slopoke17's Avatar
slopoke17
Default Water temp meter not working
I just purchased a 1977 and the water temperature gauge isn't showing any change in temperature, always stays at the bottom end. I ordered a repair guide but thanks to the postal service its lost in maine somewhere. I'm thinking of replacing the sending unit but am wondering if there is a way to check it before I spend the $30 and not need it. Any tips on where to start would be appreciated.
Old Feb 19, 2012 | 12:46 AM
7T1vette's Avatar
7T1vette
Turn ignition "ON" [engine not running]; remove wire from sending unit; see if temp gauge still reads low; touch the end of that wire to chassis ground (metal on block, etc); gauge needle should swing full scale to the right. If so, meter and wiring is fine. If no change at all, wiring may have a break or the temp meter could be defective.
