Headlight switch
Old Feb 23, 2012 | 01:24 PM
1969 DREAM's Avatar
1969 DREAM
Default Headlight switch
In between the switch and the back of the dash is an aluminum ring with an arm that screws into the top right speedo mount. Does anyone know what it is, what it's called and where I can get one? Not sure there is anything wrong with it. Just trying to be prepared as I reassemble my dash
Old Feb 23, 2012 | 01:33 PM
Roco71's Avatar
Roco71
I believe that is the ground for the switch.
Old Feb 23, 2012 | 02:16 PM
Alan 71's Avatar
Alan 71
Hi 69,
It's called out in the AIM as 'Strap'. 3928779
Because of where it's attached to the switch and pad, I've always thought it helped stabilize the switch in the dash pad. But Roco might well be right!
I don't see it listed at the vendors I looked at.
Regards,
Alan
Old Feb 23, 2012 | 02:58 PM
Sully1882's Avatar
Sully1882
yep ground strap for the switch
Sully
Old Feb 23, 2012 | 03:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Sully1882
yep ground strap for the switch...
Yah. You need it. Don't forget to install it on the new switch.
Old Feb 23, 2012 | 06:21 PM
1969 DREAM's Avatar
1969 DREAM
Thanks, I'll hold on to this one as I don't see it on any vendor sites.
To Headlight switch
