Brake Lines
I was working on finishing up the rear suspension, and the dang brake lines are the last hold up.
So I was removing the drivers side the from the dist block, the PO had rounded it, and I had to the the ole vice grips out. So I get the line out, and it appears that the damn line was smooth, after some well applied cussing I tried to thread the new line in. NO Dice, after 5 more min of cussing, contemplating burning the car down, cussing some more, contemplating kicking the dog etc...
So I guess I need to replace the brake lines, does anyone know where the front to rear line meets up? is it easy enough to just buy a straight piece at the parts store, or should I get the pre-bents?
I dont think ill be able to get the other parts off the dist block due to the tight spaces so was thinking if not too difficult (ya right) ill just do the whole damn line
any suggestions? Think I can re-tap the block? (I don't but will try anything anyone know the size? )
Thanks for listening to the rant
Ed
Oh and I wasn't ever really going to kick the dog.
I'm gathering that the dist. block to which you refer is the one just in front of the diff., in which case all you need is this block if the thread in it is gone. You say you have a new left rear brake line so the place from which you bought it should have the dist. block you need too. It's not easy to get at but not impossible. If the right rear line is OK, keep it, if not then get a new one made.Stainless is not needed, you'll be old and grey before a new mild steel brake line wears out. The current ones have lasted almost 40 years and haven't rusted through, have they? The main dist. block up near the steering box is easy to get at if the car is on a hoist and if it's not leaking, then I suggest you leave it alone.
Good luck.
Regards from Down Under.
aussiejohn
First I'm going to use parts store and ben up a new front to rear line, and redo the entire rear brake line setup. starting at the front dist block/prop valve.
Since the fronts are already done going to leve them alone for now, and then worry with them when I replace the master cylinder like in beejays thread..
I'll prolly still cuss, but the dog is safe, lol...thanks guys, and anyone see any issues with my thought process?
The fronts are
I like to upgrade stuff myself. One of those while you're at it things I guess. The OEM valve seems to work well enough, the adjustable gives you more latitude with regard to the way the front and rear apply. Is it something you want to work with meaning laying down some test patterns to see where they are locking or not. If the brakes themselves are OEM I might trust the engineered valve over my skill level in adjustment.
This past Sept. while outside Cleveland I was driving my shop truck towing a trailer of engine blocks. The shop truck is the last to get things done other than oil changes. I hit the brakes and the front right line blew. I felt the peddle drop so I hit it a couple times hard and the lind behind the fuel tank to the rear blew.
Ended up 200 from home with a truck, trailer and zero brakes. Not a good feeling.Called a friend with a roll back. He brought his truck for the trailer and the rollback for my truck. 4.5 hrs each way.
So now when I replace a rusted line I do them all. Including the rubber lines to the calipers. On the vettes I used stainless braided lines to the calipers.
Like Grumpy427 said, It's only money and well worth the peace of mind.
The rough one will be the one from the front to the rear. I'm replacing the body mounts at the same time so it should make it a little easier. If it would make it easier, you might want to make the front to rear in two pieces. If so I wouldn't use stainless. The double flair in stainless would be more difficult at the union.
