Trailing Arm Question
Old May 15, 2002 | 02:09 AM
flynhi's Avatar
flynhi
Default Trailing Arm Question
I've had a rattling sound from the right rear and tonight's inspection revealed that the outer poly bushing on the right trailing arm has worked itself loose and is outside the TA "hole". It is wedged in so the TA is not moving around too much.
I'm curious as to what difference I will feel in the "seat of the pants" after I fix this and realign.
Any thoughts?
