Quick Q on 68 shifter/crossmember brackets
Old Feb 26, 2012 | 02:37 PM
champs65's Avatar
champs65
Default Quick Q on 68 shifter/crossmember brackets
Does the shifter bracket bolt to the transmission bracket after the T.B. bolted to the crossmember?
Or does the shifter bracket bolt to the crossmember first, and then the transmission bracket bolts onto the shifter bracket?
No AIM...it was in my basement during TS Lee last fall.
Old Feb 26, 2012 | 07:28 PM
champs65's Avatar
champs65
Here is a picture of the area that I need help with.
Is this configuration correct, or is it the other way around?
[IMG][/IMG]
Old Feb 27, 2012 | 04:16 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What's a T. B.?
Old Feb 27, 2012 | 06:04 PM
champs65's Avatar
champs65
Mike, Just short for Transmission Bracket so my post didn't get too wordy.
I'm just trying to figure out which bracket gets bolted to the crossmember first before I slide the engine and trans down in. The shifter bracket looks like it will be in the way of the transmission to me, but then again I didn't take these brackets apart so I don't know what it should look like.
Old Feb 27, 2012 | 09:46 PM
Mike's 68's Avatar
Mike's 68
I just checked my pictures and the AIM for my 68 and its the same as your picture shows, tranmission bracket first then the shifter bracket next.
Old Feb 27, 2012 | 11:23 PM
champs65's Avatar
champs65
Thanks Mike, I appreciate it
To Quick Q on 68 shifter/crossmember brackets
