Doing big block swap and notice this.
Old Feb 28, 2012 | 01:06 AM
big454blockchevy's Avatar
big454blockchevy
Default Doing big block swap and notice this.
I notice that apparently someone welded into the crossmember. Kind of worried about this.
Old Feb 28, 2012 | 02:20 AM
wombvette's Avatar
wombvette
Pretty common especially with BB and heavy suspension.
Old Feb 28, 2012 | 08:15 AM
Mark Riles's Avatar
Mark Riles
If you're worried you can clean the areas up to inspect their welding and then if you're still worried you can have someone weld in some gussets for support.
Old Feb 28, 2012 | 10:18 AM
69 Chevy's Avatar
69 Chevy
BUBBA bubblegum
Old Feb 29, 2012 | 03:22 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Just had that done on my '80 with Gymkhana suspension. The lower A arm mount tends to tear loose under heavy use. My frame is great otherwise with no rust or damage. A good welding job with extra braces make for a permanent repair. Yours is not the neatest job I've ever seen but otherwise looks ok. I'd have it checked before I went too far. Good luck!
To Doing big block swap and notice this.
