Testing starter, have question
Old Mar 2, 2012 | 07:52 PM
Zapawaf's Avatar
Zapawaf
Originally Posted by tonyv123
I have the same fuel pump as you do, with no return outlet. I've been using it for 5 years now with no problems. If you do use the pump, just make sure you cap off the hard line going back to the tank. Plus you can clock the bottom of the pump to get your fuel lines where you want them.
It was recommended to me to replace it with a stock style pump because it might night make the proper vacuum yada yada. So I just went with the stock style. Wasn't that much for it anyways.
