turbo 400
Old Mar 3, 2012 | 02:48 PM
jackdaddy's Avatar
jackdaddy
Default turbo 400
just installed a new motor and transmission, a turbo 400.In a 1975, anyone have pictures of kickdown brackets and cable, car had been cobbled and old 400 transmission did not have a kickdown hooked up!! where can i get a kickdown kit with everything?
Old Mar 3, 2012 | 02:59 PM
Mark Riles's Avatar
Mark Riles
Start with vendors of Corvette parts. You'll be looking for a kick down switch and a solonoid.
Old Mar 3, 2012 | 04:41 PM
7T1vette's Avatar
7T1vette
Kickdown on a 400 is electric. The kickdown 'switch' can be anywhere (mounted to accel pedal, on throttle linkage, etc.). But, the kickdown switch then sends a 12vdc signal to the kickdown solenoid inside the tranny (mounted to the bottom of the valve body separator plate). When that solenoid opens, it dumps pressure, causing the downshift.
Old Mar 3, 2012 | 04:49 PM
Mooser's Avatar
Mooser
400 = Electric kick-down. Plug on the tranny is on the driver's side just behind the shifter cable bracket. Two spades in a "T"
I don't have an pic's of the switch, it mounts behind the acc-pedal normally but as 7T1vette it can be put other places (aftermarket)
Mooser
Old Mar 4, 2012 | 12:55 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The 75 assembly instructon manual (AIM) shows everything you need and lists the original GM part numbers.
Old Mar 5, 2012 | 05:48 PM
Mooser's Avatar
Mooser
Oddly enough, someone's got a 400 switch in the parts section right now
Mooser
To turbo 400
