msd reliability,hype
Old Mar 6, 2012 | 11:00 AM
rugerm44's Avatar
rugerm44
Default msd reliability,hype
I'm thinking about buying their tach drive dist,and 6al box.I did a search and found mixed thoughts on it.People either seem real happy without problems for years or it fails two hours after installing it.Could this be due to a installation error or is it just that big a crap shoot.If it fails can you limp home or is it dead in the water.I'm old and don't like walking.
Old Mar 6, 2012 | 11:05 AM
cv67's Avatar
cv67
St. Jude Donor '05
Heard of a lot of problems with the 6al digital boxes but the 6a non digital seem to have a decent track record.
Msd billet dist and less than impressed so was the person I eventually had to take it to to curve it cause it would never time right. Took some work.
Use a 6a box. Dont want to but with a big solid roller I dont want to deal with plugs fouling and it does that well.
Making a bypass harness couldnt hurt.
Unless you really NEED a box stick with a good blueprinted HEI or Mallory Unilite those 2 rarely if ever go bad. Good coil and call it a day
Old Mar 6, 2012 | 11:16 AM
Mike Ward's Avatar
Mike Ward
Why do you want to change your ignition from whatever you have now?
Old Mar 6, 2012 | 01:34 PM
rugerm44's Avatar
rugerm44
Because its 35 years old and has 150,000 miles on it.I'm not interested in rebuilding the old one.The technology is 35 years old also.They have come a long way since then.
Old Mar 6, 2012 | 01:45 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I have the 6 ALN box, non digital, N stands for Nascar. It is filled with a substance similar to a hardened clear silicon to isolate the electronics from heat and vibration, I have run it on 3 different cars and it is indestructable. If they are still available I would recommend it,.
Old Mar 6, 2012 | 01:47 PM
rugerm44's Avatar
rugerm44
Thanks.I don't understand why they sell something like the 6al if it dosent hold up well.I noticed even nascar mounts it inside the car.
Old Mar 6, 2012 | 02:02 PM
Mike Ward's Avatar
Mike Ward
Just get a basic tach drive HEI unit then.
Old Mar 6, 2012 | 02:09 PM
palmbeachvette76's Avatar
palmbeachvette76
I've had a Pro Billet Distributor, 6A ignition box and the blaster SS coil for close to 2 years with zero problems. I had the MSD Super conductor wires and just replaced them due to age.
Old Mar 6, 2012 | 02:12 PM
cv67's Avatar
cv67
St. Jude Donor '05
MSD recommends it I believe
most mount them without the isolators right in the heat of the engine compartment wrong place. Electronics dont like heat.
Those boxes can be sensitive to simple things such as zip tying output wires together.
Being as I hardly get to drive mine hoping it should last a few yrs.
Old Mar 6, 2012 | 03:14 PM
rugerm44's Avatar
rugerm44
I don't put a ton of miles on it but I'm planning on an engine swap in the future with a little more compression than the original eng in it. More cam more compression and a whole lot better heads.
Old Mar 6, 2012 | 03:25 PM
Garys 68's Avatar
Garys 68
Ever notice Nascar mounts 2 of them on the dash?
You will get exactly 0 performance gain with an MSD on a relatively stock engine over points, HEI, etc. Supercharged, big cam, etc they can help.
I've worked on their marine version a lot. Just about everyone has one die about every 2 years. Their "marine" distributors rust out in about the same amount of time.
I've heard that wiring the box directly to the battery with heavy gauge wire can help them live, but I've seen those die too.
Old Mar 6, 2012 | 03:43 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I have a MSD 8572 tach drive pro billet distributor, MSD blaster coil, MSD spark plug wires, and a MSD 6AL ignition box. Almost 8 yrs with zero issues. I believe most problems are from incorrect installations, people just don't seem to read the instructions! Follow the instructions, and you should have no issues.
You can mount the box under the hood, just stay away from direct heat. Mine has been mounted on the rear of the front passenger wheel well since new, no issues. You can just see it in this pic:
Here is a pic I took when I installed it:
Originally Posted by MSD 6Al instructions
MOUNTING
The MSD can be mounted in the engine compartment as long as it is away from direct engine heat
sources. It is not recommended to mount the unit in an enclosed area such as the glove box.
When you find a suitable location to mount the unit, make sure the wires of the ignition reach their
connections. Also be sure that the program dials can be accessed. Hold the Ignition in place and
mark the location of the mounting holes. Use a 3/16" bit to drill holes, install the vibration mounts and
mount the ignition.
A direct link to their instructions for the 6AL:
http://www.msdignition.com/WorkArea/...id=15032386116
Old Mar 6, 2012 | 03:47 PM
gdh's Avatar
gdh
Had the 6AL for over 10 yrs now with no issues also use it with the Petronix II.
Old Mar 6, 2012 | 04:13 PM
birdsmith's Avatar
birdsmith
I have a 6AL in my now-streetified [Mustang] race car that I installed in 1994. It has outlasted three engines. Not one problem. The car can sit for months without being started, hit the fuel pump, crank it and BANG! it lights off. They may be outsourcing some of their production nowadays so that may account for some of their issues but all the racers still use their stuff. That says something. I've seen a lot of other systems come and go- Jacobs, Crane, etc., etc., but MSD is the constant.
The NASCAR guys run two boxes on the off chance that one fails (and they sometimes do) you can immediately switch to the other...
Old Mar 6, 2012 | 09:23 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I have the MSD 6AL and matching distributor on my 72, and for me the reason was a performance one. But… unless MSD changed their instruction manual, there is nothing in there about jump starting your car while charging your battery!
If you have an MSD box and your car battery is dead, DO NOT put a jumper box or battery charger on the car and attempt to start it! There is a huge chance you'll blow a diode in the MSD box and it is not covered by warranty.
You might get away with it a few times but eventually the odds will catch up to you! For me, if I need to charge the battery I remove the cable and charge it. But never try to jump the car...
IMHO,
Willcox
Old Mar 6, 2012 | 09:32 PM
Ben Lurkin's Avatar
Ben Lurkin
St. Jude Donor '09
Get a pertronix or crane electronic conversion kit for your current distributor. Works great and no box.
Old Mar 7, 2012 | 02:35 AM
elle88's Avatar
elle88
I have the MSD 8572 and 6ALN .no issues
i still don't understand why c3 chrome bumpers owners place the msd box in the engine bay when there's plenty of space inside the passenger side dash. Mine is there. no engine heat and more neat wiring.
To msd reliability,hype
Old Mar 7, 2012 | 08:49 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I am not sure about others, but I put mine in the passenger wheel well for easy access. I can remove the side grill on the car and have perfect access to my box.
Old Mar 7, 2012 | 10:46 AM
elle88's Avatar
elle88
here is mine. no need to access it unless for replacing the rev limiter plug but i can quite easily do it from under the dash, non need to open it
Old Mar 7, 2012 | 11:46 AM
rugerm44's Avatar
rugerm44
Thanks for all the information guys.Ordered the tac drive dist and the NASCAR controller.Probably mount it behind pass side dash panel.I have a vintage air unit in there but I think I can squeez it in.
