Wiper door problem on '68??
Old May 15, 2002 | 11:07 PM
hudman's Avatar
hudman
Default Wiper door problem on '68??
My wiper door needs to be pulled up when you cut them on. Wipers work fine. Door promptly closes when you cut off the wipers.
Cant seem to find any leaks.
Any ideas?
Old May 15, 2002 | 11:11 PM
PRNDL's Avatar
PRNDL
Default Re: Wiper door problem on '68?? (hudman)
can you raise the wiper door using the override switch under the dash? MJ
Old May 15, 2002 | 11:13 PM
hudman's Avatar
hudman
Yes
Old May 15, 2002 | 11:14 PM
hudman's Avatar
hudman
Someone mentioned it could be the wiper switch. Is this possible or a goose chase?
Old May 16, 2002 | 09:15 AM
JSB69's Avatar
JSB69
If '68 is the same as '69, the wiper switch sends a signal to a soleniod valve mounted behind the tach which starts the door closing process. The override bypasses the solenoid so it's a good place too start. I remember a thread on disassembling and cleaning this valve not too long ago if it's OK electrically. This part is not available from any of the catalog suppliers, so if you need one, you'll have to find one used.
Old May 16, 2002 | 05:32 PM
Marks69BB's Avatar
Marks69BB
Default Re: Wiper door problem on '68?? (JSB69)
Below is the thread to repair the solenoid:
http://forums.corvetteforum.com/zerothread?id=271473
Enjoy! :cheers:
Old May 16, 2002 | 05:58 PM
verskel's Avatar
verskel
My wiper door needs to be pulled up when you cut them on...
So, you're saying that it opens partially ??? :confused:
To Wiper door problem on '68??
