Front frame crossmember
Old Mar 10, 2012 | 06:58 PM
Stoutmaker's Avatar
Stoutmaker
Default Front frame crossmember
I need help again! The only rusted part of the frame on my '69 is the v- shaped front crossmember. I have purchased a replacement and it looks as though 6 bolts are keeping this member in place.
When replacing this piece do I need to do anything special or can I just remove the bolts and bolt the new piece in place? Have not dealt a lot in framework so I thought I'd ask before I started.
Thanks!
Old Mar 10, 2012 | 08:53 PM
rponfick's Avatar
rponfick
Are you talking about the crossmember that the radiator sits on? If so, it just bolts on. No big deal.
Ralph.
Old Mar 11, 2012 | 10:14 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the assembly instruction manual (AIM) and take a look at the diagram of the factory installation. Front bumper horseshoe bracket and bumper guard brackets bolt to the X-member.
To Front frame crossmember
