73 vette rear lights
Old Mar 10, 2012 | 11:51 AM
fzfox's Avatar
fzfox
Navigator
Default 73 vette rear lights
Hi, Just finishing reassembly 73 vette and have NO REAR LIGHTS of any kind???All connected and grounded and all the bulbs are new and fuse is new? Thanks
Old Mar 10, 2012 | 12:48 PM
Alan 71's Avatar
Alan 71
Hi fvf,
I realize you said 'grounded'.
Each light has a ground connection, and then there's a ground connection to the frame member. Did you get that one too?
Regards,
Alan
7T1vette's Avatar
7T1vette
Have you checked with a voltmeter for 12vdc between the ground point you chose and the 'hot' pin on one of the lamp sockets?
Old Mar 10, 2012 | 07:32 PM
fzfox's Avatar
fzfox
Navigator
Thanks guys, guess I was just tired. Connector on harness under dash not plugged in. All is well, thanks again....
Old Mar 11, 2012 | 10:17 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by fzfox
...Connector on harness under dash not plugged in...
That 'splains it.
To 73 vette rear lights
