brake light problem
Old Mar 11, 2012 | 08:51 PM
KevinG's Avatar
KevinG
Default brake light problem
Finishing up a restoration on my '69 4spd coupe and running into a brake light issue. All new harnesses have been installed.
-with parking lights on, right taillight will totally go out with brake pedal pressed, left works fine
-without parking lights, right taillight only lights up in single filament, left works fine.
-took grounds off both right lights and grounded directly to frame grinding down paint where eyelets make contact - still doing the same thing.
I'm reallly baffled of what is causing this
Old Mar 12, 2012 | 12:36 PM
KevinG's Avatar
KevinG
Anyone?
*crickets*
Old Apr 13, 2013 | 08:43 PM
kenarab's Avatar
kenarab
Cruising
Default I have the same problem
Originally Posted by KevinG
Anyone?
*crickets*
I 'm experiencing a similar (maybe the same?) problem. With no lights on, when I press the brake pedal, left is full bright. right side is dimmer, (single filament??),With lights (parking) on, when I press the pedal, Left side is full bright, ride side goes totally dark. Any help appreciated.
Old Apr 13, 2013 | 08:45 PM
kenarab's Avatar
kenarab
Cruising
I have a '79 4-spd. Sounds like a C3 issue??
Old Apr 13, 2013 | 08:49 PM
jnb5101's Avatar
jnb5101
is the right side bulb inserted properly? pull the bulb and check the contacts and the ground from the socket to the frame.
Old Apr 13, 2013 | 11:43 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I think this is one of he most helpful schematics we've done in while.. it gives you all the needed info without clutter.
I need to upgrade this to include the parking and marker lamps.
Your issue sounds like:
Ground or Parking lamp extension issue
Bulb issue.
Old Apr 14, 2013 | 09:17 AM
KevinG's Avatar
KevinG
Here what happened to mine. When I was restoring it, I painted theight housings. This was causing the lamps to have a poor ground. I took a dremel and ground down all the paint in the cylinder where the bulb and socket mount into. Put everything back together and everything worked great.
So take sandpaper or a dremel and sand down to bare metal on the taillight housings Inside the small opening.
To brake light problem
