It seems piston #8 is not working in my SB... when I remove spark plug no difference at all... is there any troubleshooting guide I can follow in order to understand what's wrong? The car had in the past problems of timing, which I solved, but now I realized I'm missing one piston...
You're not missing a piston, you're missing compression on one cylinder...I think.
When you pull the plug, do you get a squirt of air out of the plug hole as the engine is running - should be a rapid puff-puff-puff?
With no compression, you have valve(s) that are adjusted wrong, the piston is forcing the air/fuel mix either back out through the intake valve or out a slightly open exhaust valve...or both.
If you had a missing piston, it would shake your teeth out from being so far out of balance and that plug would be drenched in oil slung onto it by the crankshaft.
Yes thats what I meant.. sorry for my english! Of course I have the piston inside the engine, but I have no compression...
We all knew what you meant. Do what MDJ21 suggested, pull the valve cover and make sure your valves are working properly. Could be a camshaft, lifter, pushrod, etc. problem.
Not sure what tool brands are available in your neck of the woods but stay away from the cheapies...maybe Facom or one of those brands. I have a Craftsman that I've had forever...
It's possible that spark plug wires for #8 and #4 were swapped which led to very late timing on #8 - this would cause it to run very hot, melt the boot and probably do more damage. Please verify that you had the correct firing order... 18436572.
Firing order is ok, a week ago I had timing issue, 2 degree retarded, but I fixed when it started to overheat the temp...
Yesterday I checked wiring on #8 plug and the boot was melted... what does it means?
This is more than likely your whole problem. Retarded timing causes the cylinder to fire late (as the valve exhaust opens). I have seen headers glowing orange from incorrect timing. You cooked your wire and/or boot and spark is arcing to the header or nonexistant and are getting no spark to the #8 cylinder. It can also burn exhaust valves if not caught and can blow the head gasket between # 4 - #6 or #3 - #5 due to the exhaust ports being siamesed at the center cylinders and the excessive, cocentrated exhaust heat causing uneven head expansion. If the plug wire is the only problem consider yourself lucky. Replace plug wire and see if the prfoblem is resolved. If not, investigate further.
woow, I did "only" a couple of miles with the wrong timing....
Good. It is probably just a cooked wire/boot. It does not take long to get the header glowing orange right where it attaches to the head with retarted timing. It is thin material and the exhaust valve is open during plug firing even if timing is just a little retarted. A couple miles will do it. Spark takes the path of least resistance. The plug is a resistor with a gap. Arc from the boot to the header is the path of least resistance.
