tending to my frame's rotted sections
Old Mar 13, 2012 | 08:17 AM
roytheroach's Avatar
roytheroach
Default tending to my frame's rotted sections
i have to replace the rotted sections on my frame, right in front of both rear wheels, commonly referred to as the "achilles heel." i dont want the hassle of completely lifting the body off... is it possible to unbolt the body and only lift the back a few inches to cut and weld? i already have the 23" frame sections and cross member, and a pro welder buddy of mine is gonna do the welding. it also came with sleeves to go over the welds, and we are securing everything in place to ensure a totally straight frame.
Old Mar 13, 2012 | 08:28 AM
Spacecoast's Avatar
Spacecoast
Check this thread out on what can be done with the frame on..
http://forums.corvetteforum.com/c3-g...-my-vette.html
Not sure how bad the rot is on your frame, but this may give you an idea.
Old Mar 13, 2012 | 08:53 AM
roytheroach
i can stick my fist in the driver side frame rail, about half as bad on the pass. side. thats why i just got brand new sections
Old Mar 13, 2012 | 09:01 AM
roytheroach
http://www.zip-corvette.com/ProductDetails/StyleMasterDetails.aspx?pid={150cf1c9-a13a-40f3-9638-7591d8dde377}&gid={545b7b0f-062b-4296-8d57-114540c6eead}&GroupName=Frame+Repair+Com ponents&pname=75-77+23%22+Frame+Rail+Repair+Kit&Referer=& Alias=&ptct=SGR-SR&CTitle=&#
the middle picture on the right
replacing A9 and #3 crossmember completely
To tending to my frame's rotted sections
