Big Block Clutch
Old Mar 13, 2012 | 10:41 AM
bill69's Avatar
bill69
Default Big Block Clutch
OK I am at a loss. I have a 70 454 with a Muncie 4 Speed M21 transmission. I broke a tooth off the 1st gear drive. So I decided to replace the clutch at the same time. My transmission has a 10 spline shaft but for the 454 they only show a 26 spline count. So I am trying to understand why that would be. I am certain(as certain as I can be) the car is all orignial...I bought it from the original owner and he had a book detailing everything including oil changes..etc. So I assume he didn't change the transmission and clutch.
Old Mar 13, 2012 | 11:59 AM
MelWff's Avatar
MelWff
where are you looking? I had no problem finding them.
http://www.summitracing.com/search/Y...?Ns=Rank%7cAsc
Old Mar 13, 2012 | 12:17 PM
bashcraft's Avatar
bashcraft
It should be a 10 spline. 26 spline wasn't used in corvettes until '71.
Old Mar 13, 2012 | 12:35 PM
Ironcross's Avatar
Ironcross
all you need to do is exchange the disc....another reason to buy most of your parts locally.......
Old Mar 13, 2012 | 12:41 PM
69 Chevy's Avatar
69 Chevy
1st design Muncie '63-'65 was a meduim duty trans with 7/8" countershaft.
2nd design Muncie '66-'70 used a 1" countershaft, 10 spline input.
3rd design Muncie '71-'74 used a larger diameter, fine 26 spline input and also came with both a fill plug and drain plug.
To Big Block Clutch
