power window repair
my windows have a hard time going up and down so I bought a new motor for the driver side. I still had the same problem... infact the new motor could not roll the window up as far as the old one. I thought connectios or electrical but those seem to check out.
At this time nothing is holding the window up so the track system has to be clogged or something else. Even when I push or pull with my hand the window is still hard to roll up or push down.
I think the assembly needs to come out and be cleaned. However, seems like there are tons of parts that is needed to rebuild the regulators/assembly. Not sure which ones I need. The parts list is what I am trying to find. I found an old article by corvette magazine but all the links are broken.
how can I tell what I need? Rip it all out and go from there?
The main arm that has the gear on it that is operated by the motor has a rivet that holds it to the housing. I would soak it with penetrating oil and make sure it moves freely. Also the other arm that is connected to the system has a wheel that role on a housing that is bolted to the door. Make sure there is no gunk in that track. These window mechanisms must be in tip top shape to work at all any problem will affect their ability to work. Even when they are in good shape you may need a weather-stripping lubricant to help them work.
Either the window mechanism (not the motor) is binding due to wear, lack of lubrication, etc. or the window switch is corroded/burnt on the contacts and is not passing adequate current to run the motor.
Yea, mine has not been supported for weeks now and still has not fallen.
Thanks for the information. Once I finish my HID headlights I am going to start on the doors. I know I will have to remove everything and go from there.
@7T1vette - I thought it was the window switch/contacts so I replaced those and solder in new ones. That did not fix the problem. I never thought about the mechanism until recently.
How the heck do I get the whole thing out of the door? I removed the window which was a pain. Removed the roller runners. Now how do I get the rest of it out? I took off all the bolts and the whole thing can be moved but I can't remove it from the top of the door.
I remember posts talking about a rivet and stuff? Where is that at?
I am also working on the power window of my 79'. When I am looking for parts they always refer to Left window (LH) and Right window (RH). Which one is the Drivers window?
Sorry for such a silly question. I am that naive :P
You need the procedure for taking that motor AND linkage mechanism out of the door. And, it's a 'dilly'. The Chevrolet Chassis Service Manual is the only source for that info, AFAIK.
You need to remove the motor and linkage as a set! If you removed the motor without inserting a bolt/nut in the linkage to lock it in place, it will just fall...with the window! And, if you put the bolt/nut in place, then you can't remove the "locked" linkage.
Procedure is complex. In general, you raise the window, remove the glass, lower the linkage, get the side rails out of the way, remove some retaining screws, and then 'jack' the linkage/motor back and forth to get it out of that lower access hole.
If you can't find the procedure or don't have the CCSM, don't try it.
Received 1,252 Likes
No easy task!
http://www.corvettemagazine.com/tech...power-rebuild/
After you get the glass out you have to remove the top (long) track from the back and top of the door.
Circle all the bolts with a marker so you can align everything just as it was.
Then remove the small track by removing the two bolts and sliding it off the roller.
Then remove the front and rear vertical tracks.
Next collapse the regulator and remove it from the access hole at the bottom of the door.
You may find the old grease has turned to gum and that makes the rollers stick instead the rolling freely.
Take a close look at all the rollers as you may have to order some.
Left and right are as seated in the drivers seat.
