New Meats!
Old May 16, 2002 | 05:00 PM
ebowtie's Avatar
ebowtie
Default New Meats!
What is a good replacement tire for my 72 Shark?? I'm thinking of going to a 60 series radial, any thoughts or experiences would be appreciated.
:cheers:
Old May 16, 2002 | 05:04 PM
Corey_68's Avatar
Corey_68
Default Re: New Meats! (ebowtie)
I just put (4) Firestone Firehawk 255 X 60 X 15's on my 68. Great ride, and they look very nice. :yesnod:
Old May 16, 2002 | 05:18 PM
Rockn-Roll's Avatar
Rockn-Roll
255/60-15's are the perfect replacement...they fit with no rubbing, and have the exact same circumference so your speedometer will still read correct. I chose the BFG Radial T/A and they work just fine.
Old May 16, 2002 | 05:56 PM
verskel's Avatar
verskel
Default Re: New Meats! (Rockn-Roll)
Ditto - got 'em on my ride, too. :yesnod:
Old May 16, 2002 | 06:05 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
same here!!! 255/60-15 BFG Radial T/A on all 4 wheels.
However - I am thinking in changing the rear tires to 275/60R15 to get a little bit more
traction with the new engine....
:cheers:
Olivier
P.S. I have 275/60R15 (rear) and 255/60R15(front) Firehawks SS20's on my Duntov!
I like both - the BFG and the Firestone tires. The Firestone tires are a little bit
cheaper and look better (the white letters)
Old May 17, 2002 | 12:01 PM
ebowtie's Avatar
ebowtie
Default Re: New Meats! (Corey 68)
Looks like the votes are in, thanks for the responses. :D
Old May 17, 2002 | 04:07 PM
madmaxgt's Avatar
madmaxgt
I have 255 60/15 on the front and 275 60/15 on the rear. I really like the profile it gives!
Old May 17, 2002 | 04:27 PM
Alwyn678's Avatar
Alwyn678
Default Re: New Meats! (madmaxgt)
That does look good.....Any problems with them rubbing?
Old May 17, 2002 | 04:37 PM
madmaxgt's Avatar
madmaxgt
Default Re: New Meats! (Alwyn678)
Before I restored the frame the rear was close, but now with everything new there is plenty of room!
Old May 17, 2002 | 10:32 PM
AV76's Avatar
AV76
I'm also looking for new tires. Will 255 X 60 X 15's fit on stock rims? I have heard that they will, just want to make sure. Thanks
Old May 17, 2002 | 10:38 PM
LT1driver's Avatar
LT1driver
I am using 255/60/15 on all four corners for my 70 :cool:
Old May 17, 2002 | 10:40 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: New Meats! (AV76)
Another vote for BFG 255/60/15. They look awesome. Big meats are cool. Plus I think they ride great compared to what was on the car before. :yesnod:
Old May 17, 2002 | 11:05 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
I put 255/60VR15 Pirelli Scorpion Zero on all four corners of my '77 on my 15 X 8 ralleye rims. They fit with no rubbing and they handle great. :cool: The VR rating is good for 149 mph :eek: I bought them at http://www.tirerack.com for $85 each plus shipping. ( $ 38 for 4 to PA ) They are listed as a "sport truck tire". This gives you a slightly stiffer sidewall which helps in the handling. HTH
Old May 17, 2002 | 11:15 PM
Chris@VetteFinders's Avatar
Chris@VetteFinders
Platinum Supporting Dealership
Default Re: New Meats! (JRD77VET)
:lol: when I saw the use of the word "meats" I had to check it out.
THIS is what I call meats:
Just got a set for my "truck"
To New Meats!
