Need new carb - thoughts
Old Mar 19, 2012 | 10:51 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Which Qjet.
Pete, which Qjet do u plan to use? I may have a good core. I have a couple with the choke removed too - one is my rebuilt spare/never used - and with will work on any intake (but has no choke of course). I have some others cores too and know a good shop for rebuilds.
Send a PM if i can help ya,
cardo0
Old Mar 20, 2012 | 10:58 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
cardo0
Thanks cardo, PM sent.
Old Mar 20, 2012 | 12:08 PM
MelWff's Avatar
MelWff
Lemans Pete:
Holleys do fit, you just have the wrong series carb. I have the stock L-46 air cleaner on an old 3310-1 Holley which is a 4150 series versus the 4165 series. The difference is the float bowl design. The 4165 series has side hung floats the 4150 has center hung floats. If you look at your air cleaner you will see the upward projection in the front and back which were put there to clear the float adjustment on the 4150.
Old Mar 20, 2012 | 12:16 PM
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Originally Posted by LeMans Pete
Well today's ride didn't go so well then the secondaries kept dumping after I let off the gas. Its currently and old Holley 4165. Idle is pretty terrible (I can't get it lower than 1200 rpm) without tearing into it. What I hate the most (petty comment coming) is that it won't fit under the stock air cleaner assembly. Bubba did a beautiful (terrible) job at modifying the old air cleaner base by cutting off the crankcase vent tube, plugging it with what looks like a bottle cap, and poorly rewelding it in a new location. Sans flame arrester.
I've heard bad news about aftermarket quadrajets, but i would like something that would fit the stock L46 air cleaner assembly.
Any recommendations are appreciated.
Get a hold of Cliff Ruggles.
He's on here. He literally wrote the book on Qjets and making them perform.
Old Mar 20, 2012 | 06:01 PM
birdsmith's Avatar
birdsmith
Mine was doing it when it was parked, and since it didn't have externally adjustable floats it was a real PITA to try and stop it via float adjustment. I tried everything to get it to stop with no luck and finally gave up. I really like Holley carbs for their ease of tunability, etc., but a lot of that seems lost on the 4165/4175 since it's a single feed carb and you have to open it up to adjust the floats. IMO Holley could have made that car a lot more useful by putting adjustable floats and a dual-feed inlet setup on it...
Old Mar 20, 2012 | 09:07 PM
81 c3's Avatar
81 c3
holley 670 street avenger has my vote
Old Mar 21, 2012 | 02:18 AM
Tim H's Avatar
Tim H
Holley spreadbore are not easy to tune and based on a quadrajet which makes them junk in the first place.
Old Mar 21, 2012 | 06:26 PM
Vette5.5's Avatar
Vette5.5
"Cliff" is surely a good Q-Jet guy, and probably a good idea getting a hold of Lars Grimsrud in CO, at v8fastcars@msn.com. He'll send you his Q-Jet papers, with tons of information. Q-Jet haters have always been alive and well, but I'm certainly not one of them. Thinkin' you're best at fixing up the carb you already have, then maybe a Q-Jet for the street. Get with Lars on this, as not a big fan on commercially rebuillt carbs.
Old Mar 21, 2012 | 07:26 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Check these folks out.
http://customrebuiltcarbs.com/index.shtml
Old Mar 22, 2012 | 11:14 AM
LeMans Pete
Originally Posted by MelWff
Lemans Pete:
Isnt the 4150 design a square bore?
Old Mar 22, 2012 | 11:24 AM
ripforrey's Avatar
ripforrey
Always had good luck with Summitt; not not much with Jegs; Talk to the technical staff at Summit they can tell you if new carb will fit.
Old Mar 22, 2012 | 11:39 AM
birdsmith's Avatar
birdsmith
Pete, you're right, the 4150 is a squarebore carb. Again, the marketing schtick on the 4165 isn't entirely forthcoming...it fits the spreadbore hole pattern and has the fuel inlet moved to the same location as a QJet but the similarity ends there. You need a different air cleaner base than your stock one along with a 1" shorter filter element and the vacuum tap on the back of the manifold has to be modified as well, though it sounds as if yours may have been already modified to make it work.
The only ways that a 4165 is really superior to a QJet are in the increased bowl capacity and available 'double-pumper' cofiguration. It's not really much easier to work on than a QJet because the transfer tube is always a headache to deal with when putting it back together, and they have that damnable leaking secondary booster issue which I have heard of from a number of guys on this forum and have dealt with myself.
Personally my own issue with QJets is that (like a lot of carburetors) they don't do well when they sit idle for extended periods and the airhorn very easily warps when they are the very least bit overtorqued, causing all sorts of issues. They're also ugly. But when they are working right they do work very well.
I would say that if you want to go with a maintainable, understandable carb then get the 4150 and buy an inexpensive low-rise aftermarket intake to bolt it onto. You will sacrifice a little bit of low-rpm economy but it will fit under your air cleaner base and they are modular and very easy to tune-set the floats, set the idle, choose the right power valve, and jet from there. If you just absolutely have to get it running right with stock equipment then a QJet is the way to go but if you're not good at rebuilding them yourself (I know I'm not!!) you'll have to depend on a REPUTABLE rebuilder and those guys are getting rare.
Hopefully I've addressed the biggies in this post...my previous posts on this thread were done under duress (work) but I had a little free tiume to give you a proper answer today so there...hopefully you get this sorted out and get your Vette running like it should.
Old Mar 22, 2012 | 04:34 PM
  #33
scottyp99's Avatar
scottyp99
...and you can't even retro fit fuel bowls, because the accelerator circuit doesn't line up! Who's idea was that?
Keep the shiny side up!
Scott
Old Mar 22, 2012 | 04:58 PM
  #34
BlackC3vette's Avatar
BlackC3vette
Will the 670 fit under a stock air cleaner base?
