82 Operating Temp
Old Mar 18, 2012 | 02:11 PM
Stickman82's Avatar
Stickman82
Default 82 Operating Temp
Assuming my 1982 CE has a 160 degree thermostat, what should the oil and coolant temp gauges read after the engine is warmed up? Right now it appears they stay in the 165-175 degree range after 15 minutes at highway speeds.
Thanks!
Old Mar 18, 2012 | 08:21 PM
terry82's Avatar
terry82
you do not want the motor to run that cool .the computer likes it around 180 .your water temp should read 180-200 oil 175 -190.
Old Mar 18, 2012 | 08:33 PM
drwet's Avatar
drwet
You should be running 180-200. Nice problem to have in a Corvette. Guys are usually more concerned about running too hot. A hotter thermostat should do the trick.
Old Mar 19, 2012 | 05:24 AM
BarryK's Avatar
BarryK
160º t-stat is too low.
from the factory your car came with a 195º T-stat and it was DESIGNED was run in the 195-215º operating range as the higher temps help keeps emission levels down. If for some reason you need the car to run at lower operating temps (although for the life of me i wouldn't know why since these are the temps the car was made to run at) you could go to a 180º t-stat and possibly lower your operating temps IF YOUR COOLING SYSTEM IS UP TO IT.
Assuming the cooling system was working well enough to drop the temps even lower with the 160º unit than that low of a operating temp is too low as it isn't high enough to effectively burn off all the vapors in the crankcase and you will end up with condensation developing, causing sludge to develop in the crankcase and you also get an increase in wear in the cylinders.
Do yourself a favor and go back to the factory 195º t-stat or at least to a 180º if you really insist on a change.
Old Mar 19, 2012 | 05:48 PM
mark6669's Avatar
mark6669
Engine should have 195 thermostat and run 200-210 degrees needs to be that hot for the injection to work properly.
Mark
To 82 Operating Temp
