I have a carb setup, rochester q jet, bought car last summer. Has 348 in it...weird I know. Was fine last summer and just this week it will stall, sputtered like it is being starved and dye out ONLY when I corner hard. The harder I corner the faster it will dye out...the lighter/slower, the less.
Just started yesterday...I tried carb cleaner today...no luck.
Most likely fuel starvation. I would start by looking at the float level. I suspect there's not enough fuel in the bowl and when the fuel sloshes around its uncovering the jets and you're sucking air. I'm not a Q-jet expert so I can't tell you exactly what's happening in there, but I think that's the most likely scenario.
Agreed... it could alsobe the opposite, fuel too high and you're splashing.
Start by checking the float and float level. If the carb hasn't been rebuilt in a while, the float could easily be worn out too...
Check your fuel pressure. At least you don't have to take the carb apart to see if that is a factor.
If that is ok then I would definitely say that the float is not set right or has partially flooded, affecting the fuel level in the bowl. If you have to take it apart then you might as well get a carb kit and a float. Clean it up then put it back together with new parts.
if it were blocking flow...wouldnt it happen in full throttle acceleration and not just cornering?.....
Pressure issues are more likely going to cause WOT acceleration issues, and float level issues are more likely to cause cornering issues. (although a low float level will also cause the car to starve during WOT as it won't pick up enough.)
Honestly, if you do this right, you'll end up putting in a new filter AND a new float, so it'll be hard to tell which one was the source of the original problem.
I had the same issue with my car. In a sharp turn, occasionally the engine would die. I opened the hood and checked the carb, it was flooded out.
Ultimately, it turned out to be the float level was set to 0.25" which is way too high for my Q-jet. Adjusted it down to 0.420" (see Lars Q-jet Tuning Paper for year specific levels) and the problem never came back.
Moving the float level this much did require checking the air/fuel at all speeds. But maybe replacing your float and setting it to service manual height, with a new seat and filter will fix your problem.
I have the same problem with my Q jet. Just started recently. The air/fuel ratio gauge showed the mixture getting richer the harder and faster that I cornered. I rebuilt the carb, and lowered the float level to 3/8", thinking the fuel was sloshing over. It has somewhat improved, but it still isn't right.
Maybe I should lower it some more?
Most Q-jets have a phenolic (fuel-capable plastic) insert that fits in the upper portion of the fuel bowl. This minimizes fuel 'slosh' or 'spill' and prevents fuel starvation when turning. If you don't have one, you need to find one for your carb.
Otherwise, the float is either set too high or too low.
Floats!
Years back when I used to repair Ferrari's the 308 GTB had the same problem. If you made a sharp turn, the car would stall, due to the weber floats.
Ferrari then made the 308GTSi which was injected and the problem went away.
Open the carb, re-adjust your floats to the manual, check your fuel pressure and make sure there is fuel in the tank.
Trouble should be gone
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
well who actually knows but for arguments sake assume that there is just enough flow to allow WOT....and no more....now take this minimal amount and push it to the the outside of carb because of going around a turn. some times its hard to know which is the problem just as shark racer says. i had an austin healey 3000 and my buddy had one also and his would always stall out....we went through everything and finally determined it was a rusted out fuel line that had something in it that would block flow...that took a lot of effort to figure that one out
69 chevy- it is the W motor...odd combo, will look to sell, just dont know what to put in...
bobs77vet...weird...murphy's law on that one!
Well, I checked everything and took it for a ride...NO issues... I think the carb is tired and needs a rebuild...the oil has started turning a little quick...since I just changed it last week. Also, it seems a little more rich out the pipes...
very nice today...took car out...smelled a little more richer...noticed some fuel on the intake manifold...looks like a CARB REBUILD!....AND it did act up from time to time....
