Anyone using Autozone Brake Calipers?
Old May 16, 2002 | 09:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Anyone using Autozone Brake Calipers?
Just wondering if anyone was using these calipers. Both of my fronts are leaking. So something has to be done. The ones on my car are VBP that have been on there for who knows how long. I was just curious. Thanks for any input.
Old May 16, 2002 | 10:41 PM
zwede's Avatar
zwede
Default Re: Anyone using Autozone Brake Calipers? (Eddie 96)
I'm using them. Been 2 years or so and they're fine sofar. Look through their boxes. I managed to find some brand new ones in boxes that said "rebuild". Not bad getting a brand new caliper for $70, with a lifetime warranty.
Old May 16, 2002 | 10:46 PM
Alwyn678's Avatar
Alwyn678
Default Re: Anyone using Autozone Brake Calipers? (zwede)
I am done with Autozone and Advance.... for important parts....But if Zwede uses them I am sure they are fine...
Old May 16, 2002 | 11:22 PM
ORVette's Avatar
ORVette
I have two rears on and they seem to be fine. Lifetime warranty. I had to fight with them a little on the price. Other forum members said they had bought them for $59.95ea., and my local AZ wanted $119.95ea. Wouldn't even call the other out-of-state AZ I confirmed the $59 price with to do a price match. A couple emails to the company headquarters, and I got them for $59.95 each.
Old May 16, 2002 | 11:36 PM
bigvette1's Avatar
bigvette1
Default Re: Anyone using Autozone Brake Calipers? (ORVette)
That's a super point on prices we know. Use their web site and price the parts with your local zip and then price them with some other zip.
Old May 16, 2002 | 11:44 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: Anyone using Autozone Brake Calipers? (bigvette1)
Had four of 'em on my '78. Never a problem.
JB
Old May 16, 2002 | 11:55 PM
jackson's Avatar
jackson
How long ago did you buy and ... what zip / area did you find the original $60 price?
Old May 17, 2002 | 02:20 AM
72rdstr's Avatar
72rdstr
I've got AZ calipers on mine and have no problems at all. Good quality, good price, lifetime warranty, counter help as sharp as the trailing edge of a BB in flight... What more could a man want? :yesnod:
Old May 17, 2002 | 03:09 AM
Sting Raycin's Avatar
Sting Raycin
Default Re: Anyone using Autozone Brake Calipers? (72rdstr)
I just put a pair of fronts on mine. They were $83.99 each. I'm about to replace the rear set too, they are $69.99. That was at store #0551 in Idabel, OK
Jason
Old May 17, 2002 | 09:51 AM
sb69coupe's Avatar
sb69coupe
I've got them on all 4 corners of my '69. I've been pleased and the best part is that you can drive down the street and swap one if it starts leaking, instead of waiting for shipping both ways.
Shannon
Old May 17, 2002 | 03:22 PM
Eddie 70's Avatar
Eddie 70
For the difference in money I may give these a try also. It looks like most people are having good luck with them. But there is still that one bad apple which should be mine. Someone suggested that I just replace the bad o-rings and be done with it because the VBP calipers are sleeved and should still be serviceable. Wouldn`t the AutoZone calipers be sleeved also?
Old May 17, 2002 | 04:02 PM
Jman's Avatar
Jman
I just called AZ here in Houston on some calipers. They are FENCO brand. Lifetime warranty. Fronts are model C138, and run 79.99. Rears are model C140, and run 59.99. I definitely need to replace my fronts. I may do this instead of Vette brakes.
Old May 17, 2002 | 04:29 PM
Ken73's Avatar
Ken73
Cruise-In III Veteran
Actually, Autozone has TWO calipers - one that is NOT sleeved and one that IS. The more expensive of the two are sleeved. Get those! You can always get the o-ring conversion kit (around $20?) for them now or later. The sleeved ones are definitely worth the money!
Old May 17, 2002 | 10:11 PM
Eddie 70's Avatar
Eddie 70
Default Re: Anyone using Autozone Brake Calipers? (Ken73)
Ken, Thanks for the heads up on that. This is valuable information when it comes to something like that, sleeved or not sleeved.
To Anyone using Autozone Brake Calipers?
